Kleemann headers ... with stock pulley or bigger pulley?
I am going to buy the Kleemann headers (and delete primaries) and send the ECU to them for tuning/deleting codes.
However, I am not sure whether to stay on the stock pulley or go bigger (and by bigger, I mean their 168 pulley).
I am debating for this main reason:
--I just don't want to be spinning all through 1st gear and make most of 2nd useless. This will basically make the car not as fast from a dig or slow roll, am I right? I want to be able to get the power to the ground.
For those that have just headers with stock pulley, or had that and upgraded to a bigger pulley - advice would be GREATLY appreciated.
I don't want to drop a few grand more and the car is basically spinning with anything more than 1/2 throttle.
Any help would be awesome.
Thanks in advance.
In a car with maybe 300 - 400HP you can just floor-it and hold on while the car does all the work. When you start talking about cars with more power than that (especially 2WD versions) driver skill becomes a lot more important. Roll into the throttle as hard as the rear tires will allow, constantly reading that feedback from the tires and backpedaling as necessary to get the most possible from the car.
ESP helps from a dig if you are feeling too lazy to really "drive". The real attraction of adding more power than the car can handle in low gear is the way it adds urgency at highway speeds....and beyond. Being able to mash the gas at 75mph and get ferocious acceleration well beyond 100, 120, etc. would be awfully addictive.
-G
1. Add a Quaife limited slip out back
2. Add a set of aftermarket toe-links for the rear suspension
Those two things seem to make a big difference (in addition to the alignment and tires) for guys trying to put down big power and also makes the whole system more predictable and easy to handle when the tires DO break loose.
-G
Is it safe to drive around with aftermarket headers and no tune?
Going with headers usually drops boost by at least 1lb. and YOU MUST TUNE AFTER HEADER INSTALL..my car went from 483hp to 460hp after header install and no tune...after tune 493hp...if your going to do it, do it right.
GT, my car ran extremely rich after the header install. I cant remember the exact #s but, AFRs were very high thus robbing the engine from making the power it could have when tuned properly for headers. I agree you dont have to but why leave 30+ HP on the table not tuning.
