Warped front rotors E63 W211
Happen to me two times. OEM rotors and pads both times. Getting expensive in the long run L
What kind of pads do you guys recommend? I don’t care if they are noisy…
Thanks!
On rotors I can't help.
Ceramics are known to be one of the most vital and essential compounds that influence braking capacity. Every material has been carefully chosen for the MX72 in order to produce minimal noise and dust while producing high friction at lower temperatures. The MX72 improves upon the ever-popular CC-X compound in that braking stability is improved at higher temperatures. And yet, the MX72 actually decreases rotor wear. Even pedal feel, which is already typically great with semi-metallic material pads, was further improved upon. The MX72 is the ultimate, dual-purpose, street / light track compound.
Endless ME-20 -- Race Pads
Competition pad with high and stable mu levels at high temperatures while maintaining low wear. Developed for highly competitive touring cars focused on driving technique. Suitable for both street and track conditions. Popular in BTCC, WTCC, PWRC, International Rally.
both options are in stock ready to be shipped.
I know off one person, similar to the OP, that ran OEMs on the track and they lasted 1 day. Pagid Orange lasted him 5 track days.
You might want to tailor your suggestion that way instead of just rehashing company marketing propaganda.
Sorry
Just my helpful $0.02
Sorry
Now obviously having a dedicated track pads when on the track would be completely ideal, but for most that is not a very viable option. The MX72's allow you to drive to and from the track with no changes, or hassles.
Sorry, couldn't resist.
P.S.
Don't forget; OP was also asking about longer lasting rotors.
P.P.S.
Track to me means road course with numerous laps in a 15-20 min session. What does it mean to you? Maybe OP should clarify. Based on his post I think I know his answer.
P.S.
P.P.S.
to me tracking is doing 6-8 15-20 minute sessions... at one of the numerous tracks that we have here in So Cali such as buttonwillow, big willow, streets and auto club
You have a PM
I will be putting these on my car this Christmas. I will be using evosport 2 piece on the rear.
That being said, I have never had a disk warp, and I have turned the calipers bronze from the heat. With the RacingBrake disk material you can more safely run an aggressive pad. Evosport warns you away from anything EBC.
You should only concern yourself with the fronts. The rears just go stock pad.
I have mentioned the rotors.
My pads will be stock for now.
Titanium shims (the rear does not need them, but they were a set).
Evosport brake lines.
MB brake fluid, it is damn good stuff.
I plan a big DIY write up.
A dual purpose street/track ENDLESS pad would work great... I have a good bit of time on the ENDLESS stuff and used it for daily driving and some hard track use.. Was very impressed.... No need for 2 pad sets...
EDIT* I should add that the experience isn't with AMG vehicles....
Subscribed
Front Rotor
Rear rotor
Front and rear xt brake pads
Racingbrake feedback & review link:
