engine oil dipstick grommet replacement
Old May 20, 2012 | 12:50 AM
zkeller's Avatar
04 E55
Can someone elighten me as to how to remove the engine oil dipstick? It will not pull out of the engine. It seams to be stuck on something in the pan.
I need to replace this grommet as it is leaking pretty badly. Please do not tell me the oil pan needs to come down.
Old May 20, 2012 | 02:52 AM
moosejaw's Avatar
none
There is no dipstick. Oil is measured from inside the car
You can buy a dipstick from the dealer. What exactly are you trying to pull off?
Old May 20, 2012 | 11:44 AM
berti_00's Avatar
2016 Cls63s AMG
care to tell how it is measured inside the car
Old May 20, 2012 | 12:42 PM
zkeller's Avatar
04 E55
There is a tube for the dipstick that goes into the top of the oil pan. all of the cars have them. When I had the heads off and pushed it to the side, it stretched the grommet. Look under your hood and you will see the trans and the engine dipstick tubes that have a red plastic cap on them.
Old May 20, 2012 | 12:49 PM
desired_speeds's Avatar
2007 SL55 AMG
gauge cluster scroll through the temp/mph folder until you see the check oil level menu then turn on ignition and wait for it to measure the oil.
Old May 20, 2012 | 02:52 PM
berti_00's Avatar
2016 Cls63s AMG
i tried it and didn't work
Old May 20, 2012 | 03:10 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
sounds like the tranny oil dipstick tube that has a red cover on
Old May 20, 2012 | 06:27 PM
moosejaw's Avatar
none
Yes that is correct
Once you break the cover you have to replace it with a new one from the dealer.
The dipstick that you could buy, for about $ 60.00, was not permanent, but a shop tool only.
To the OP, as said before our cars dont come with Dipsticks. Its only to be inspected by shop techs with their dipsticks. The dipstick does not stay in the tube. Once you break the seal, you will have to replace it with a new one.
Old May 20, 2012 | 10:58 PM
zkeller's Avatar
04 E55
There are two dipstick tubes, the trans and the engine oil. Trust me, it is there. it is the tube that the dipstick goes into. It bolts to the passenger side cylinder head.
Old May 20, 2012 | 10:59 PM
zkeller's Avatar
04 E55
No, there are two, engine oil and trans.
Old May 20, 2012 | 11:05 PM
zkeller's Avatar
04 E55
Thank you! And my question is, can it be removed without pulling the oil pan? I cannot seam to get it out of the pan.
Old May 21, 2012 | 12:07 AM
moosejaw's Avatar
none
Are you talking about the red cap shown above?
Is it me or images not showing up on MBW?
Hit link if not...
http://www.flickr.com/photos/peterho...n/photostream/
Old May 21, 2012 | 01:05 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Hit link if not...
The red cap should be the tranny tube cap not the engine. I still could not find the engine oil tube.
Old May 21, 2012 | 02:20 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
My car came with a dipstick
Old May 21, 2012 | 04:18 AM
2007 SL55 AMG
that red cap next in between the supercharger and the surge tank is the engine oil. The black cap with a small red tab behind passenger side valve cover is the trans dipstick. it only has the red tab if it was removed and replaced before or maybe no red tab if it wasn't ever put back. comes from factory with a black tab.
Old May 21, 2012 | 08:34 AM
Roverron's Avatar
ML63
he is asking about taking out the whole tube not just the cover or fill cap. I think he is trying to fix a leak at the bottom ot replace the metal tube.
Old May 21, 2012 | 09:24 AM
moosejaw's Avatar
none
I just realized this as well
Turns out the OP is very experienced with these cars
He did his own head gasket if I am correct. YOu wouldnt know with his post count.
I feel silly.....What a waste of my posts?????
Old May 21, 2012 | 10:22 AM
berti_00's Avatar
2016 Cls63s AMG
did you guys check my thread about this?
https://mbworld.org/forums/w211-amg/...you-using.html
Old May 21, 2012 | 12:47 PM
benz_addict's Avatar
V12TT
Mine came with a dip stick but I removed it, unnecessary place where oil leaked from. I check the oil level from the cluster.
It's only bolted to the passenger side valve cover, just pull hard, turn twist etc you will get it out.
Old May 21, 2012 | 01:08 PM
zkeller's Avatar
04 E55
Maybe mine was added after the fact or a model year change?? I will take a pic when I get home so you guys do not think I am an idiot. You will see the trans tube behind the passenger side surge tank and the engine oil tube in front of it.
The engine oil tube goes right into the block at the base of the oil pan. there is a grommet there. From wrenching the tube back and forth when I did the heads I oblonged the grommet and it is leaking like crazy.
when you unbolt the tube from the head and try pulling it out of the block, no go.
Again, my fear is I will have to pull the pan down to get the tube out. that will blow as you must slacken the suspension, motor mounts and then support the engine in order to get the pan out!
Old May 21, 2012 | 01:11 PM
V12TT
K so I took a pic just for your sake to help you remove it, the bottom of the dip stick is left, the top is right...
Attached Thumbnails engine oil dipstick grommet replacement-477102_10150918542027899_506122898_10006355_2112637768_o.jpg
Old May 21, 2012 | 02:13 PM
zkeller's Avatar
04 E55
Did it pull out from the top?? I cannot get it to budge. Did you have to remove anything else besides the bolt that attaches to the head?
I see there is a sensor on the pan near the tube. Maybe that needs to come off?
Old May 21, 2012 | 05:47 PM
Alps's Avatar
i stand corrected, it doesnt come from factory but the additional tube is added by the workshops sometimes to enable a manual dipstick to be used.
Old May 21, 2012 | 06:10 PM
zkeller's Avatar
04 E55
so maybe there is a blank grommet for it?
Old May 21, 2012 | 06:11 PM
zkeller's Avatar
04 E55
Either way I cannot get it out
