Are W211 E55's one wheel wonders?
Old May 30, 2012 | 11:47 AM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
I've only done 2 small burnouts in my E55, and each time only one wheel spins. Is that normal for a stock E55 or do I need to fix it?
Old May 30, 2012 | 12:47 PM
e55amgrocket's Avatar
Dirt Scooters
They have an open diff for some crazy reason. I never had a problem spinning both until being at the track on drag radials. Put a Quaife in and you will be happy.
Old May 30, 2012 | 01:14 PM
nizzle's Avatar
Ok thanks, I'll check it out. Any advantage to going with a Quaife over a Kleeman diff?
Old May 30, 2012 | 01:29 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Try backing up straight with some load so that it will load of the diff in reverse since this helps keep both wheels active. Then put her in drive and witness two patches being laid down as long as you can drive her straight...
Old May 30, 2012 | 01:47 PM
nizzle's Avatar
LOL , we'll see
Old May 30, 2012 | 03:14 PM
moosejaw's Avatar
none
I'm not familiar with the specifics of the kleeman diff but the quaife offers a lifetime warranty
Old May 30, 2012 | 03:17 PM
Evolved8's Avatar
AMG Fam
x2 on the Quaife. QDF9V-2 Get a hold of James. Good product. Putting one in my car right now!
Old May 30, 2012 | 04:12 PM
nizzle's Avatar
I did more searching around on here and found that one huge benefit of the Quaife is that it's a direct swap out. Where as the Kleeman, from what I've read, is not.
