accurate data logging...
Old 08-16-2012, 05:36 PM
Toadster's Avatar
2005 E55 AMG
Looking to optimize my Dash Command setup
There are a few variables to really dial in the car...
Here are the settings I used: (some auto-generated by DC)
OBD-II Settings:
ISO/KWP Keep Alive Interval (ms): 3000
OBD-II Response Timeout (ms): 200
Disable OBD-II Mode $09 Support: OFF (default)
Minimum Bus Idle Time: 0 (default)
Specifications:
Fuel Tank capacity: 21.1 gal (US)
Engine Displacement: 5439cc
Volumetric Efficiency: 70% (estimated between 65-80)
MAF PID:*
MAP PID:*
Lambda (actual) PID:*
Lambda (commanded) PID:*
Tire Size Specification: 275/35/R18
Final Drive Ratios: 3.59;2.19;1.41;1;.83
Wheel Circumference: 80 in
Curb Weight: 4200lb (est)
Additional Weight:
Drag Coefficients: .29
Frontal Area:
Maximum Engine Speed: 6500 rpm
Minimum Engine Speed: 650 rpm
Shift Point: (most economical shift rpm?)
Fuel Type: Gasoline
Tire rolling resistance coefficient: .013 (recommeded)
Speed Correction:
* This is used to enter an external sensor PID that was not factory installed on the vehicle. If you are not sure, do not enter anything here.
any recommendations for Frontal Area, shift rpm?
also, does the Eurocharged tune modify redline?
Old 08-16-2012, 07:09 PM
GT-ER's Avatar
2005 E55 AMG
Eurocharged raises rpm redline to 6700rpm I believe.
Looks pretty cool, does it read knock retard though?
Old 08-16-2012, 07:42 PM
Toadster's Avatar
2005 E55 AMG
I thought redline was bumped a little
it shows timing advance/retard - not sure if it's logging the knock sensor other than showing the timing difference...
Old 08-16-2012, 07:51 PM
Toadster's Avatar
2005 E55 AMG
Old 08-16-2012, 07:57 PM
cij911's Avatar
one car at a time
nice pics, but remember when logging from OBD2, as you select more parameters it will slow the data transfer down significantly....i try to log just 2 or 3 items from OBD2...
Old 08-16-2012, 08:37 PM
Toadster's Avatar
2005 E55 AMG
what is shown in the screens above is in the default setup - pretty nice, minimal lag so far...
there are a TON of options behind the scenes - right now, doing good with IATs
Old 08-16-2012, 08:59 PM
cij911's Avatar
one car at a time
Todd - What IATs are you seeing ? Today I was a bit inland (only 5 or so miles from the ocean) and it was ~100 out and my IATs went from ~115 to ~160 on several 3rd gear full pulls....Crazy....
Old 08-16-2012, 09:36 PM
Toadster's Avatar
2005 E55 AMG
Just cruising around 115-123 - haven't had a clear stretch to really work it out
Old 08-16-2012, 11:04 PM
Toadster's Avatar
2005 E55 AMG
does anyone know the frontal area (coefficient of drag)? I saw somewhere on the site that the E63 is .29 - is the E55 different?
The E-Class Coupe has the distinction of being the most aerodynamic production car ever marketed, according to the automaker, with the lowest drag coefficient on record.
what about the Shift Point: (most economical shift rpm?)
Old 08-16-2012, 11:06 PM
Toadster's Avatar
2005 E55 AMG
wait - I found it...
the E55 claims a slippery 0.28 coefficient of drag.
Read more: http://www.motortrend.com/roadtests/...#ixzz23lkQKox2
Old 08-17-2012, 12:17 AM
sack5000's Avatar
2015 AMG C63 S
Originally Posted by belmarez
Truly inspiring!!
I am going to study it some tonight, looks intriguing.
Old 08-24-2012, 04:54 PM
Toadster's Avatar
2005 E55 AMG
as Jim suggested above - the specs for drive ratios is the gear ratio (1 through 5) multiplied by the final drive ratio (stock is 2.65)
so the E55 ratios should be:
Gear x Final Drive = Ratio
3.59 x 2.65 = 9.51
2.19 x 2.65 = 5.80
1.41 x 2.65 = 3.74
1.00 x 2.65 = 2.65
0.83 x 2.65 = 2.12
Old 08-24-2012, 05:43 PM
GregMB's Avatar
3.59 x 2.65 = 9.51
2.19 x 2.65 = 5.80
1.41 x 2.65 = 3.74
1.00 x 2.65 = 2.65
0.83 x 2.65 = 2.12
Toad,
Got the PLX WiFI last night but can't get it to sync with DashCommand
I did the PLX setup using 192.169.0.11 subnet 255.255.255.0
Is there an obscure setup area in DashCommand to setup the wifi connection?
-G
Old 08-25-2012, 06:21 AM
Toadster's Avatar
2005 E55 AMG
Originally Posted by GregMB
Toad,
-G
mine hooked up quickly - did you turn on the Kiwi?
(not being dumb, but I didn't realize there was a power switch)
I think in the directions you can setup the application to be 192.168.0.10
be sure to set the port to 35000
Old 08-25-2012, 07:58 AM
GregMB's Avatar
The directions said to start the car before plugging it in. Once I plugged it in the face lights up and I see it as an available WiFi device on my iPhone.
Pretty confident that the WiFi part is working. In dashCommand there seems to be an area in Setup (OBD-II data port) where you can choose either "auto" or custom IP. Default was auto, but I think maybe I should be confiding the IP and port # manually in that area? Is that how yours is?
-G
Old 08-25-2012, 08:13 AM
GregMB's Avatar
Weird. I just noticed that my VIN was automatically logged under vehicle info.
Obviously the connection worked at least briefly at one point. How much of that vehicle data has to be filled in beforehand?
Old 08-25-2012, 06:33 PM
Toadster's Avatar
2005 E55 AMG
it picked up my VIN and read the PIDs - go into your vehicle setup and enter in as much info and validate the PIDs - it should work like a champ
Old 08-25-2012, 08:53 PM
gazosnic's Avatar
e46 m3, w211 e55
How do you get it to show IAT's? I didnt see that as an option? Also what # is normal?
Old 08-25-2012, 09:23 PM
Toadster's Avatar
2005 E55 AMG
4th tab (with the engine pic) - labelled INTAKE
with my new FT-P Heat Exchanger and a new I/C (Bosch) pump - I can generally have IATs ~10*F hotter than ambient (so far that's what I've seen)
Old 08-27-2012, 04:59 AM
Half Fast Drivr's Avatar
CLS55
Toad, I am in the process of doing the same tweaking for better readings. Firstly, double check your tire circumf...
Also, have you had any luck getting torque or HP readings? If so, do you feel those could be reliable figures, or just calculations based on data entered x phones onboard accelerometer?
I just got this app, and the newest china-made wifi device, and am really looking forward (or at least hoping) to this app providing accurate and valuable data.
Thanks, and best,
Lastly, ditto the port #, and ".10" for the IP addy.
Old 08-27-2012, 09:24 AM
cij911's Avatar
one car at a time
Generally one see IATs ~20 - 25 degrees above ambient after driving for a bit (cruising), but once you go WOT you will see the IATs climb high. I cannot speak for Todd's setup, but with mine on repeated back to back 3rd gear pulls, with ambient ~93 my IATs will go above 165. For just one pull they will stay below 140.
Old 08-30-2012, 04:56 PM
Toadster's Avatar
2005 E55 AMG
Thanks, and best,
yes - I modified to 80" for circumerence - it's close, but not 'perfect'
I haven't played much with it lately, just been watching IAT and timing
Old 08-31-2012, 09:40 AM
lowprofile's Avatar
E55
Those screen shots sure look pretty, but your real life data logs leave a lot to be desired.
Just checking the three you took while dynoing, linked below. The first two scans, your IAT never refreshed so you had zero data points for IAT. The third scan, it refreshed at the start of the pull only. The other parameters refreshed at a better rate, but still incomplete data. Were you possibly logging more than the four parameters shown?
https://mbworld.org/forums/5334334-post34.html
Old 08-31-2012, 09:50 AM
Toadster's Avatar
2005 E55 AMG
there's a LOT of data logged - take a look
https://docs.google.com/open?id=0B0b...WVyM3I2S2VoejQ
Old 08-31-2012, 10:06 AM
lowprofile's Avatar
E55
Link not working.
So which parameters were you logging aside from what you shared?
Quick Reply: accurate data logging...
