1/4 Mile Times
The best run was the first - 12.506, had problems getting traction on the other 4 runs and ran 12.8-12.9. Track temperature was 82F.
Details:
RT .592
60' 1.845
1/4 12.506
MPH 110.80
MPH was 109-110 on the other runs but 60 foot times were 2.04-2.10 as the wheels would spin. I ran with ESP on and nailed it from idle.
Any suggestions for better launches?
I belive you can improve thou.
Assuming you are not power braking, I'd suggest not to floor it immediately, try just over half throttle, let it go to about 20 mph and them floor it.
Make sure your front tires are at about 45 lbs, and the rears at about 25 or less is spinning persists, a/c off (of course), more than 1/2 tank of gas, with your spare in the car (you need the extra weight on the rear).
Keep improving!
I have tried both ESP and non with the best runs with it on. I just get too much wheelspin with it off to get good launches.
I find that the best times have come with a mild powerbrake of around 2300 to 2400 but I am still experimenting. The trick seems to be to ge the car to allow a bit of wheelspin without shutting down too much power. A big powerbrake has just resulted in the computer shutting way down....
I will be taking it to the strip in a couple of weeks for some real numbers.
Enjoy
I have 2500 miles on mine now and have been playing with my G-Tech. Take it for what it is worth, I have been running around 12.27 most of the time. My best run was 12.17. Even if it is off by 2/10ths it is still close to the 12.4's that have been reported.
Enjoy
PS: Awesome 60 ft though, 1.8 that is great !! the time is good too, street tires or drag radials??
very impressive MPH!!!:o
03E55AMG, what tire pressure did you run on the rear?
I was expecting better times
Well, the more you spin the higher trap speed.
Of course, you'll need to have a set of wheels for daily driving if you do that...
