PITA Rear Rotor Bolts
Old Sep 25, 2012 | 04:44 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
How do i get these *******s loose? I have the rear of the car on ramps... Tried an electric impact wrench 'returned it' -- too weak 230lbs... tried to breaker bar it but not enough space.
Will a 350lb impact wrench do the trick???? Or do i need to put the car on a rack and break the bolts loose with a longer bar? Would heating up the bolts help alot??
Old Sep 25, 2012 | 04:46 PM
marc.l's Avatar
2003 E55 estate
I assume you mean the T18 bolts that hold the callipers on ?
Old Sep 25, 2012 | 04:57 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
longer 1/2" bar will do the job
Old Sep 25, 2012 | 05:51 PM
komp55's Avatar
ML550
What Shardul said. You doing upgraded calipers or just going to paint them?
Old Sep 25, 2012 | 11:40 PM
5280 Busa's Avatar
2019 S63
If they are at 130 Lb/Ft or more even a breaker bar is going to be difficult since there is not much room to get it in there with leverage. I Just did my rear pads and rotors last weekend but I took into the dealer first and had them break the bolts loose and retighten to 100 Lb/Ft...much easier up on a lift. They did this for free since it was in getting camber bolts installed. I bet you could get it done for under $25 if that's all they are doing for you.
It's nearly impossible to get those loose without the car on a lift IMO
Old Sep 26, 2012 | 09:26 AM
tpick23's Avatar
E63
Those are a ***** to get loose. I had to get them loosened by a shop too. Even they had to go find their highest rated impact gun.
Old Sep 26, 2012 | 09:43 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Its almost impossible tbh... I nearly gave up 3 x over a full day trying to get them off. I ended up using a 3' breaker bar ... also I dont think I used a E18 socket. Think I ended up using a hexsocket and it managed to bind and bite with the bolts better. Once you hear the creak you know you had it cracked ... nicest sound I've heard wrenching for a long time.
The best way is to get an inline open socket, so you are applying the torque in line with the head of the bolt - like this....
http://www.img-automotive.co.uk/torq...r-14-18mm.html
most sockets leave you a little offset and when the pressure mounts the torque gets deflected.
Good luck ... !
Old Sep 26, 2012 | 09:56 AM
I just want to do an OEM rotor replacement. Not enough room to get the leverage but I did manage to rip a non-impact socket with my normal rachet.
I guess I can try it later when I am better prepared.... either I find more space 'lift'. Or I get a stronger impact wrench.... already have a new impact socket and breaker bar.
While I am in the area, I want to cut out the dust shields.
Will applying some heat 'torch' help break the bolts?
Old Sep 26, 2012 | 10:17 AM
bghark's Avatar
2006 E55 AMG
The most bad A$$ impact wrench avaliable. 1000 ft/lbs brake torque.
I have yet to have a bolt or nut that can beat it.
http://www.factoryauthorizedoutlet.c...FclM4Aod3ikAVw
Old Sep 26, 2012 | 10:22 AM
marc.l's Avatar
2003 E55 estate
Still not got mine off yet ......
Going to take it too the local garage and have them do it with a impact gun .
Old Sep 27, 2012 | 05:15 PM
Quattrodude's Avatar
2011 E550 - 4Matic, 2008 ML550
Great reason to get new toys...I was trying to do my front brakes and using a 300lb wrench had no luck...
4 days later - this showed up at my door?
and Zzzwwwiiingggggggg...off comes the bolts...And only a meer 51 smackos!
This weekend I plan to do the rears...I'll let you know if the 500lbs this one has is enough...
Cheers
JP
Old Sep 27, 2012 | 05:51 PM
marc.l's Avatar
2003 E55 estate
Good tool !!!
Got mine off in the end , long braker bar and a strong boot
The fronts are just as bad , broke 2 sockets so far , quite hard to get on to the bolts square . A little tip I wish I had found earlier for fronts , remove the caliper from the bracket first , then you can get to the bracket bolts a lot easier .
Should soon have my 12 piston calipers and floating discks on the front
Old Sep 27, 2012 | 06:12 PM
I turned my wheel and was able to get this Wrench on the bolt with a standard impact socket...
But I did buy 4 NEW Caliper bolts (that also came with blue loctite on them) for the re-install - safe and cheap and not that the ones I pulled off were stripped but if I needed to pull them off again - they were nice and not rounded in anyway.
Thought it was odd though the fronts were HEX and the rears are TORX?
Cheers
JP
Old Sep 28, 2012 | 11:15 AM
stevebez's Avatar
kit for new handbrake shoes has hex bolts for rear calipers now.
I wonder why....
Old Jun 11, 2013 | 05:43 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Defeated today as well. Pains me to put the old pads back in and have to go with my $$ to a shop just to break these loose.
The front hex on my 2007 was easy. Guess the better angle had by turning the wheel helps, but no way those were as tight.
Old Jun 11, 2013 | 08:24 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Good to know that they are a pain in the azzz
Old Jun 11, 2013 | 09:40 PM
groove66's Avatar
2005 e55
I always thought the rotor was held on by the little m6 torx or allen head set screws.
when you say car is on ramps how are you loosening rotor bolts off , if you still have the wheels on? or do you mean jackstands and wheels are off..
or are you reffering to the caliper bolts ?
Old Jun 11, 2013 | 09:53 PM
FromM3toAMG's Avatar
07 E63
i quickly gave up on mine.. MB dealer had issues getting them off also so i didnt feel bad.
Old Jun 11, 2013 | 11:44 PM
Ok, everything is back together. New Evosport rotors, OEM pads, and Titanium shims. I will post a new thread after I download some photos. Time to clean up and bed the new pads.
Old Dec 7, 2014 | 06:56 PM
Rallyboy383's Avatar
2004 E55
Where did you source the new rear caliper bolts from? I am having a tough time with the rear bolts on my e55. I am afraid that if I keep trying that I am going to round the bolt head off. Please help!!
Old Dec 8, 2014 | 02:08 AM
KMS11's Avatar
Audi S4 (sold), E46 M3 (sold) 05 E55 silver/black(sold)
Had to give up and have the rears done at the shop.
