[GunMoto's] '05 Pewter W211 E55 | First PICS
Old Apr 23, 2013 | 01:54 AM
GunMoto's Avatar
EG8 | E46 | W211
Retrofitted facelift headlight inserts.
Cliffs: Use DEPO facelift-look headlights for prefacelift fitment and swap inserts. Do not use OEM facelift headlight inserts as donor.
I got this idea from slobenzo , who used DEPO facelift-look headlights for prefacelift fitment as the donor, which was a straightforward swap, here: https://mbworld.org/forums/w211-amg/...eadlights.html
I preferred to use OEM parts so I picked up a pair of facelift halogen headlights. I learned this is NOT a simple swap if you are using OEM facelift headlights as the donor.
  • prefacelift is a 1-piece insert.
  • facelift is a 2-piece insert (large oval face, turn signal reflector)
Observation #1: the turn signal reflector insert has 2 prongs that clip into the housing, which the prefacelift does not have.
Solution: double-sided tape or adhesive
Observation #2: the actual position of the hole, where the turn signal bulb socket is inserted, was laterally offset by about 15mm!
Solution: I hacked the prefacelift turn signal portion of the insert and created a hybrid using the facelift reflector
Before:
After:
Old Apr 23, 2013 | 02:33 AM
FromM3toE55's Avatar
2003 E55 AMG
looks 10x better!
Old Apr 23, 2013 | 08:33 AM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Your car and photography always looks amazing!
Are those Enkei NTO-3s I see?
Old Apr 23, 2013 | 08:55 AM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
He definitely has the right glass. 50mm/1.4 Prime for the win. And NICE job on the lights. I love the new look.
Old Apr 23, 2013 | 11:25 AM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
cleann...if only that lip would fit LCI 211's
Old Apr 23, 2013 | 12:38 PM
GunMoto's Avatar
EG8 | E46 | W211
Originally Posted by FromM3toE55
looks 10x better!
Thanks again pare!
Thank you! It's an E46 328i 4dr running 18x10 265/35-18 square setup (front & rear).
Yes, facelift headlights give it that 'fresh' look. Only a D3000 body though.
True that! You should get the one that FromM3toE55 is currently running on his LCI bumper.
Old Apr 23, 2013 | 01:33 PM
  #32
berti_00's Avatar
2016 Cls63s AMG
heyy i pm'ed u about those yellow city lights?? hit me up if you can. Car looks gorgeous btw
Old Apr 23, 2013 | 02:09 PM
  #33
GunMoto's Avatar
EG8 | E46 | W211
Thanks mang!! PM Sent.
Old Apr 24, 2013 | 03:56 AM
  #34
pnoyworx's Avatar
10 E63, Sold -07 E63
We gotta meet up in July, I'll be in SD/Temecula area for a week. TimeToy is from SD also.
Old Apr 24, 2013 | 04:55 AM
  #35
Jvee's Avatar
E55 AMG 2004
Looks very sharp! What brand are your carbon front lip & rear defuser?
Old Apr 24, 2013 | 10:12 AM
  #36
GT HAUS's Avatar
PREMIUM SPONSOR
GT63 S, G63
Wow! Your AMG looks amazing
How is the exhaust treating you? Hopefully you are happy with it. We'd love to see some more photos if you ever have the chance... at your leisure of course
Old Apr 24, 2013 | 03:34 PM
  #37
ArmoE55's Avatar
2006 E55
Slightly off topic question:
Is your garage floor epoxy? What product did you use? Power wash and two coats? Anything else?
I am about to take on the garage floor project one of these weekends ...
Old Apr 24, 2013 | 07:52 PM
  #38
GunMoto's Avatar
EG8 | E46 | W211
Seriously! I believe there are a few other members that are also from SD. We should definitely get a meet going!
I'm running the (Carlsson style?) front splitter and 3-fin rear diffuser from Gary@Sunveer, here:
https://mbworld.org/forums/w211-amg/...shipped-2.html
I mounted the front splitter using nuts, bolts, and fender washers.
For the rear splitter, I removed the rear bumper and test fitted the diffuser, then pre-drilled holes and used self tapping screws to secure it. Only the black plastic portion of the rear bumper was drilled, making certain the screws weren't too long that it penetrated through the diffuser. It's probably overkill, but I placed 14 mounting points as shown below.
Old Apr 24, 2013 | 08:21 PM
  #39
GunMoto's Avatar
EG8 | E46 | W211
Thank you! Yes, I am definitely happy with the Meisterschaft exhaust...and totally due for an updated photoshoot!
Yes, I used 2 boxes of Rustoleum (solvent-based) garage floor epoxy. It's been so long ago when I applied it, but I remember the general order was like this:
  1. pressure wash floor
  2. degrease/scrub floor
  3. pressure wash floor
  4. acid etch floor
  5. pressure wash floor multiple times
  6. allow floor to fully dry
  7. apply first coat of epoxy
  8. allow allotted time to dry for foot traffic
  9. apply second coat of epoxy
  10. allow allotted time to dry for vehicle traffic
PM me if you have any other questions.
Old Apr 24, 2013 | 08:51 PM
  #40
2EASy's Avatar
2005 E55 AMG
Your car is sick and the reason I'm staying with the pre facelift bumpers...
Can you PM me about the yellow city light? I'm really really liking the look.
Old Apr 24, 2013 | 09:00 PM
  #41
GunMoto's Avatar
EG8 | E46 | W211
Thank you! Yes, I like the facelift look but I prefer the prefacelift bumper if I had to choose between the two. I like the aggressive "edge" the facelift has, but the prefacelift has a nice proportion overall with the w211's lines.
PM Sent.
Old Apr 24, 2013 | 09:06 PM
  #42
Gavillan's Avatar
2012 Toyota Tacoma Baja
Very clean ride. Loos amazing!!
Old Apr 24, 2013 | 09:49 PM
  #43
hpV12's Avatar
Audi A4
Gunmoto... Absolutely stunning example of a W211 AMG. Well done.
Old Apr 25, 2013 | 08:21 AM
  #44
ArmoE55's Avatar
2006 E55
  4. acid etch floor
Awesome stuff, thanks. I will be doing this soon.
On Topic:
Do you have more shots of the rear diffuser installed on your car? I am seriously on the fence on whether I want this diffuser from Gary or not.
Any more shots directly behind the car or at some angle? Thank you.
Old Apr 25, 2013 | 02:17 PM
  #45
GunMoto's Avatar
EG8 | E46 | W211
I will take more shots this weekend to detail more of the fitment, but here's what I have for now.
EDIT: I do want to thank the s4treg for posting the rear bumper removal DIY here:
https://mbworld.org/forums/w211-amg/...r-removal.html
Old Apr 25, 2013 | 04:30 PM
  #46
GT HAUS's Avatar
PREMIUM SPONSOR
GT63 S, G63
Great shots, and thanks for sharing!!
Old Apr 29, 2013 | 09:32 PM
  #47
GunMoto's Avatar
EG8 | E46 | W211
Here's an inexpensive mod update...scuffed, prepped, then shot the fender emblems black. De-badged trunklid emblems but had to keep the star because of its mounting holes. Instead of the factory 85mm diameter emblem, however, I mounted a smaller 70mm star emblem. It's a subtle difference, but I like the it...
Ideally, would like to fill in the trunk holes and just have ///AMG on the right hand side of the trunk.
Sort of debating on a facelift trunk finisher...thoughts? Or, perhaps a prefacelift euro trunk finisher if I could somehow source one, lol.
Enjoy!
Old Apr 29, 2013 | 09:34 PM
  #48
berti_00's Avatar
2016 Cls63s AMG
nice ***
Old Apr 29, 2013 | 09:45 PM
  #49
ricecooker713's Avatar
C63 E63
Beautiful car, very clean, it was nice meeting you
Old Apr 29, 2013 | 10:27 PM
  #50
MAN55LE's Avatar
04 E55 AMG
Sickness, just picked up my pewter beast a month or so ago. Your car looks amazing and is giving me ideas.
