[GunMoto's] '05 Pewter W211 E55 | First PICS
Old Oct 8, 2013 | 08:40 PM
  #101
GunMoto's Avatar
EG8 | E46 | W211
Originally Posted by CharlyE500
Pewter rocks !
Yessir!!
Originally Posted by BagMan
Thanks GM!
Car is CLEAN!
Any thoughts on LED rear runnng lights also?
I did LED rear turn signals for the instantaneous on/off cycles. I thought about running LEDs for rear running lights but didn't think it would be a huge benefit or difference so I likely will just leave as-is.
Old Oct 8, 2013 | 11:45 PM
  #102
MAN55LE's Avatar
04 E55 AMG
Polished valve covers look amazing, my 55 is pewter too. Love your thread it always has nifty updates!
Old Oct 18, 2013 | 02:25 AM
  #103
GunMoto's Avatar
EG8 | E46 | W211
Another update.
I wanted more purposeful pedals, including a dead pedal. I have UltimatePedals for my E46 and was very happy with the final product, so I chose them again to make a set for the W211.
They already have a template for the W211 and I modified my order by adding a flange to the dead pedal, extending the width of the brake pedal, and went with anti-slip on all except the gas pedal.
Overall, I am extremely pleased with the upgrade. Transitioning my right foot between the brake and accelerator is perfect for me. (Maybe time to start learning left foot braking, lol.)
Old Oct 18, 2013 | 04:29 AM
  #104
cm60k's Avatar
WaaaaW Maaan, very nice job.....
ZAYED,,
Old Oct 18, 2013 | 12:05 PM
  #105
GunMoto's Avatar
EG8 | E46 | W211
ZAYED,,
Thank you sir!
Thanks bro! You found my little Easter Egg, lulz.
Old Oct 18, 2013 | 12:12 PM
  #106
GunMoto's Avatar
EG8 | E46 | W211
BLING BLING!!
Time to give the S/C some elbowgrease love too, lulz.
Old Oct 18, 2013 | 01:20 PM
  #107
berti_00's Avatar
2016 Cls63s AMG
looks beautiful as always brotha, that engine is very different and i love it. What was the process? is it chrome pain
Old Oct 18, 2013 | 02:27 PM
  #108
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Gun- Always look forward to your updates and photography.
With that motor shot...you've delivered again sir!
Old Oct 18, 2013 | 08:27 PM
  #109
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
Originally Posted by GunMoto
Dear sir,
You by FAR, have the most beautiful E55 I have seen to date, and I have seen plenty.
Awesome camera work as well. I NEEEED to get that steering wheel for my E63.
Thank you for sharing.
Old Oct 21, 2013 | 05:40 PM
  #110
tolentino71's Avatar
W211 E55
BLING BLING!!
enough said.....FLAWLESS!!!
Old Oct 28, 2013 | 01:34 PM
  #111
C_DirtyTwo's Avatar
a land yacht.
what instrument cluster is that? I love the black instead of the silver....also how much you want to do my tails like yours?
and lastly, what did you use to get your supercharger so clean? Mine has stains on it I cannot seem to get off.
Old Oct 28, 2013 | 03:05 PM
  #112
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Nice Pewter Beast bro!
I have an 05 Pewter as well, but I blacked out my stock AMG wheels matte black. I too love the pics and updates! Most importantly your avatar boasts a YZF! I used to work and race for Yamaha and Im stoked to see another and a fanatic track guy.
Next time your up in the OC (more specifically HB) drop in and say hello!
DG
Old Oct 28, 2013 | 03:07 PM
  #113
berti_00's Avatar
2016 Cls63s AMG
its stock i am sure he just most likely sprayed it black, took it a part. Def looks better than the silver
Old Oct 28, 2013 | 03:14 PM
  #114
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
You can't spray it because the paint will cover the clear parts where the light is supposed to shine through. Like the traction control symbol and gas symbol.
I did this mod by swapping the black faceplate from my wife's E320.
The E320 now has silver face with black dials.
The E55 now has a black face with white dials, like GunMoto's
Both look better.
Old Oct 28, 2013 | 03:27 PM
  #115
C_DirtyTwo's Avatar
a land yacht.
Both look better.
yeah after some searching i noticed on the regular E class it has the black faceplate. How difficult is it to swap the faceplates?
Old Oct 28, 2013 | 03:43 PM
  #116
GunMoto's Avatar
EG8 | E46 | W211
Hey bro! It was a lot of manual labor, lol! The basic process was using a flap wheel to knock down the sand cast surface, then wet sanding from 320 > 400 > 600 > 1000 > 1500 > 2000, then used a buffing wheel and started with black/emery compound > brown tripoli > white rogue. This was my first DIY polishing project so it's not a professional result but I am definitely happy with the way it turned out!
If you're not the patient type, I would consider having the work done. Plus, the turn around time would be much quicker. I chose to DIY because of the learning experience and budget, which I'm sure you follow as well from your many DIY threads.
Thank you! Unfortunately the valve covers get covered by the air boxes, but I guess that gives me more reason to finish off by polishing the supercharger, lulz.
Originally Posted by p30amg08
Dear sir,
Wow, thanks for the kinds words! I'm definitely going for a simple/clean look with daily-driveability.
Def get intouch with berti_00 to see if he can one-off an E63 wheel for you. Otherwise, you can simply find a CLK63 Black Series wheel because you have the type of airbag for it for a straightforward swap.
Lulz...thanks pare!!
Old Oct 28, 2013 | 03:51 PM
  #117
GunMoto's Avatar
EG8 | E46 | W211
This:
Both look better.
White on silver didn't seem to have that nice contrast so I went for the traditional white gauges on black faceplate. Classic look I must say!
BagMan is right, not possible to paint without a flawless result. Just find a cheap cluster with black face plate on eBay. The swap is fairly straightforward. If you run into a snag, just let us know!
Old Oct 28, 2013 | 04:00 PM
  #118
GunMoto's Avatar
EG8 | E46 | W211
Lemme check if I have any left over tint vinyl.
If it's simply grease and grime, you can use a garden hose, simple green, and a toothbrush. I usually just go to the local self wash, and use their degreaser, let it work in for a minute or two, then pressure wash the grease and grime off.
Old Oct 28, 2013 | 04:09 PM
  #119
GunMoto's Avatar
EG8 | E46 | W211
DG
DG! Thanks bro! Time for a Pewter meet, heck, time for an OC w211 meet!!
Yessir, 1st gen 1999 R6...slow as a donkey but quick and nimble for it's era, lulz. I def want to get back into club racing again.
Most important is your avatar.
Old Oct 28, 2013 | 04:10 PM
  #120
Natibeastcat's Avatar
E90M3, E55 AMG
I've added this page to my favorite's and will visit often for inspiration!
Old Oct 28, 2013 | 04:11 PM
  #121
C_DirtyTwo's Avatar
a land yacht.
Lemme check if I have any left over tint vinyl. If it's simply grease and grime, you can use a garden hose, simple green, and a toothbrush. I usually just go to the local self wash, and use their degreaser, let it work in for a minute or two, then pressure wash the grease and grime off.
Cool, thanks for the info. I tried the self wash, but no luck. Need something stronger, I'll try the simple green.
and for the tails, I'm talking about the LED turn signals
Old Oct 28, 2013 | 04:19 PM
  #122
BagMan's Avatar
It's really easy. I had both cars done in a half hour.
Old Oct 28, 2013 | 04:32 PM
  #123
GunMoto's Avatar
EG8 | E46 | W211
Quick update: An impromtu photoshoot after working a bit late (cargo box is temporary guys, lol). Enjoy!
Old Oct 28, 2013 | 04:40 PM
  #124
BagMan's Avatar
Tight!
Old Oct 28, 2013 | 05:59 PM
  #125
FromM3toE55's Avatar
2003 E55 AMG
