Smaller SC Pulley + Big Crank Pulley Who Is Running This?
All info on the kit is greatly appreciated.. The good the bad and the ugly... I've personally only heard positives so that's a huge +.... Let us outsiders in on your fun...
Do you know how many rpm they spin it?
Just like the SLR, I'm trashing the stock inefficient cooler and using top mounted coolers to help with cooling efficiency. Not sure what to expect but I'll find out shortly.
Ted
I knew the gearing was different and with much better intercoolers but I'd like to know what rpm the blower is efficient too. That will tell us how far to go with pullies.
Ted
Ted
As for why we are not seeing more small sc being run, it's because of the sc shaft and bearing. Snowgard was able to made a 82mm sc pulley but it was very costly. Shardul & Co sc pulley is 84mm. If they can find a thinner bearing they can make the sc pulley even smaller.
