Question regarding Pulley
Old Dec 13, 2012 | 12:48 PM
viren.89's Avatar
2004 E55 AMG
Hello,
Recently I got Eurocharged tune and noticed a difference in power but the most beneficial thing I saw was a better gas mileage. lol yeah I don't take my car to the track or anything. Mostly highway or city. So noticed a big difference.
Question is , if I get the 180mm pulley it will start making a boost of 15 psi factory is 11 psi. That means tune would have to be modified.
Does it mean getting a pulley will give me more power but will adversely affect my mileage too ???
Also my friend told me it means more pressure on the pistons, and since I do not have forged pistons or anything, it isn't exactly safe ??
cuz if anything breaks due to the pulley my warranty won't cover it either. ??
Please give me your feedback. Thanks in advance
Old Dec 13, 2012 | 01:04 PM
berti_00's Avatar
2016 Cls63s AMG
These cars have forged pistons dont they
Old Dec 13, 2012 | 01:11 PM
chawkins2001's Avatar
2006 E55 AMG
Thats a negative.
Old Dec 13, 2012 | 01:17 PM
berti_00's Avatar
2016 Cls63s AMG
Damm could of sworn I read it here on the forum from someone.. weird
Old Dec 13, 2012 | 01:24 PM
kustom2k1's Avatar
03SL55
55ks have cast hypereutectic pistons. Larger crank pulley equals higher boost, your right foot will dictate your gas milage. If you hurt the motor, take off the pulley and put the stock one back on along with your stock tune.
Old Dec 13, 2012 | 02:03 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Forged crank and Rods but not pistons. Your Highway mileage should stay the same, as the Supercharger is on a clutch but your in town mileage may go down with your foot to pedal action.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 13, 2012 | 02:54 PM
GT-ER's Avatar
2005 E55 AMG
Yep yep
Old Dec 13, 2012 | 04:35 PM
viren.89's Avatar
2004 E55 AMG
wouldn't with the tune , they would have to change the air/fuel mixture to feed the new boost settings hence meaning increase in gas consumption regardless of highway or city ?
Old Dec 13, 2012 | 04:38 PM
overZealous1's Avatar
sl55 amg
shouldn't matter in closed loop part throttle.
Old Dec 13, 2012 | 04:53 PM
kustom2k1's Avatar
03SL55
The car would need more fuel once the supercharger is engaged. Your ECU runs closed loop not under boost and open loop once under boost, its using a different set of tables.
Old Dec 13, 2012 | 04:57 PM
viren.89's Avatar
2004 E55 AMG
Okay okay, thanks all for the info.
Old Dec 14, 2012 | 05:21 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Good luck and make sure they torq the bigger pulley to the right spec. Very important
