Things just got real. PULLEY FELL OFF.
I had a solid crank pulley on my celica back in 2006...took 6 months for the vibrations to shatter the oil pump to pieces...it wasn't pretty.
All the best with the repairs man. Your car is a beast!
You are in GREAT HANDS with Jason and BIP!!!
I looked the best I could with my eyes and then used a mirror to look more from the top and the bottom of the car when I couldn't see the key. I will try to look some more and better tomorrow. I will definitely be either pinning this new stock pulley or making a new keyway for something better than the tiny key that is used. Guess I need to talk to BIP/Craig about this pin kit.
Aaron
when i took my car in for repair after my pulley came of the tech said he would never use an unwelded pulley due to lack of harmonic balancing, so i bought a welded ASP pulley the second time around and had it pinned to the crankshaft which should also act mush like a larger key GT-ER as speaking of
totally sucks for op, as i know what he's going through and its no fun at all
This is similar to the ASP pulley except that the rubber is replaced with springs:
Better or worse? Who knows.
Then hopefully Friday Eurocharged will be getting bearings back in stock for the supercharger pullies and will get one of those shipped out shortly after then have Jerry set me up with a different tune for the stock crank pulley, smaller supercharger pulley setup. Guess I will go ahead and take off my 80mm throttle body while I am at it and do the throttle body shaft grind job on it to get a little more flow in there as well since the inside is really only 78mm. Gotta keep myself occupied tomorrow so I don't go crazy thinking about getting this thing fixed.
Push comes to shove, even if the pinning fails you can still go parallel style anyways.
