2nd gear squeak
Old Jan 12, 2013 | 11:24 PM
robjon's Avatar
2005 e55,89 & 90 sterling827sli,2000 audi tt,79 & 87 porsche 928
2nd gear squeak
i have a 2005 e55 and when taking off that is from 0mph their is a squeak when it hits the next gear... anybody had that problem
Old Jan 13, 2013 | 12:14 AM
Toadster's Avatar
2005 E55 AMG
sound like maybe belt slippage?
Old Jan 13, 2013 | 12:23 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Sounds like its your supercharger engaging and you think that lil hiccup is a shift. My guess is you have the famous supercharger chirp and nothing more.
Old Jan 13, 2013 | 01:31 AM
robjon's Avatar
but it is coming from the rear of the car and the car jerks when it switches to the next gear
Old Jan 13, 2013 | 01:37 AM
03'55AMG's Avatar
AMG
I know exactly what he's talking about, my car does it too. From a standstill, taking off WITH the SC already engaged, it will go to switch to second then shift real hard and fast and let off a huge squeak, like tires chirping. Although it comes from the trans area. OP, This what you mean?
Old Jan 13, 2013 | 01:38 AM
robjon's Avatar
yeah that is it
Old Jan 13, 2013 | 01:40 AM
robjon's Avatar
so how to fix that problem???
Old Jan 13, 2013 | 01:50 AM
robjon's Avatar
will post pics in the am
Old Jan 13, 2013 | 01:55 AM
03'55AMG's Avatar
AMG
I found it only does it to me in sport, not in comfort or manual. Maybe EC can post the differences between the modes as far as the TCU is concerned.
Old Jan 13, 2013 | 01:59 AM
robjon's Avatar
this squeak is in all modes and it is driving me crazy. i have had this car in the shop 4 times and it wont go away
Old Jan 13, 2013 | 02:01 AM
03'55AMG's Avatar
AMG
Wow, maybe its your clutch? The sound does sound like some heavy slippage but quickly grabs afterwards. See if you can get a video of it to help other members here. I would but its very sporadic for me. Sounds like yours is quite often.
Old Jan 13, 2013 | 02:03 AM
robjon's Avatar
does anyone know if there is any plastic in or around the rear diff or axle
Old Jan 13, 2013 | 02:04 AM
robjon's Avatar
can i post a video on this forum
Old Jan 13, 2013 | 02:32 AM
BBBSS's Avatar
Put it up on youtube and link it here.
Old Jan 13, 2013 | 09:16 AM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
Op, do you have mods? And what mods do you have?
Old Jan 13, 2013 | 10:11 AM
03'55AMG's Avatar
AMG
From what happened to me, there is no doubt that something is slipping in the trans. Theres almost a hesitation and then when it shifts, BAM SQUEAK, then all is fine. Hopefully its nothing serious.
Old May 8, 2013 | 10:59 PM
Buxton's Avatar
2006 E55 AMG
Any update on this? Just noticed mine is doing the same 06 with 90k miles and all current on service including transmission. Only thing I'm thinking its time for is serpentine belt?
Only does it under hard load shift from 1st to 2nd no other gears and never on gentle acceleration.
Old May 9, 2013 | 06:35 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Check all the sub frame bushings
Old May 9, 2013 | 11:55 PM
DavesMeanE's's Avatar
93' 500E, 95' Corolla
Like Shardul said - Check the rear subframe BOLTS as well. They are a required replacement item whenever they are removed. if there was ever any work in the rear or rear airbags replaced - they should have has the bolt holes cleaned, and new bolts installed and torqued. If one is loose or broken, the subframe could be shifting/making noise. Also be sure there is nothing rolling around in the spare tire area...
-Dave
Old Dec 15, 2013 | 06:58 PM
Harold2425's Avatar
CL55 AMG
Squeaking noise shifting from first to second
..I am also experiencing the same problem, its not all the time but its usually under heavier acceleration. My 55 has 60k on it, all stock, and babied. Can some one please chime in to let us know a way to resolve this issue !!!!!!!!!!!!!!!..Thanks much.
