Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!!
#102
03 W211 E55
Hi
Jerry from Eurocharged is away on a business trip in London. He will be back around the 12th of March and will start returning all emails and PM's then. If it is something of an urgent nature perhaps try phoning up Eurocharged?
Regards,
OZZYAMG
Regards,
OZZYAMG
#103
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
I know Jerry is overseas....but maybe some else knows. I'm assuming the above table contains target or commanded values, and you'll still need a WB for actual AFR?
#104
We are finishing up a few detailed areas of the software and once this is done I will let everyone know.
We are also testing a version of the software that will allow the end user to make a few changes to their own tune. We will provide a base tune and the user can change a few key maps to tailor the tune to their specific needs.
Ignition: + or - 3 degree maximum in a specified load range
Fueling: Specify a lambda value for part and full throttle fueling maps
RPM Limiter: Specify a RPM Limit for Manual Mode
Top Speed: Debating on adding this...the base tune takes care of it but you never know.
Map Sensor Voltage: Adjust the maximum value
This version of the software will not be free and will be available shortly after our initial release.
The hard part is determining what we should allow the user to do.... for obvious reasons.
#116
ive read this thread front to back, i cant tell if the normal one is release yet or not. if i order this on friday how soon could i expect to see it? ive got a 195mm pulley sitting on my bedroom floor, and its just killing me.
#118
Received 1,488 Likes
This place is a joke.
I'm still not clear on where the OBDII data logs are stored? Do you have to drive around with your laptop connected, or is it somehow stored in the adapter cable/interface
#119
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
We are releasing the software this week, the datalogging portion will be a week or two
Here's a video of the software guys...
#120
#121
SPONSOR
#124
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#125
2006 E55 AMG
Just got the Eurocharged tune on my E55. Couldn't be happier! Great price, awesome service, fast turnaround. The beast is running much smoother now and pulls harder than ever.
