no spare sucks
Old Apr 15, 2013 | 08:58 PM
hank55's Avatar
e55 amg, gmc yukon, wrx, Sti, civic si, tundra
no spare sucks
cruising to work my driver rear tire got
punctured. luckily i had some fix a flat in the trunk and was able to get it to discount tire. even luckier i had warranties on my tires and was able to get both rears replaced for $75. the passenger rear had a chip in sidewall missing.
Posted from Mbworld.org App for Android
Old Apr 15, 2013 | 09:00 PM
3BNick's Avatar
2006 E55
Where did you spare go? do you have a trunk tank or something?
Old Apr 15, 2013 | 09:04 PM
E55Greasemonkey's Avatar
This place is a joke.
2004 did not come with a spare
Old Apr 15, 2013 | 09:13 PM
hank55's Avatar
best place to buy a spare?
Old Apr 15, 2013 | 09:25 PM
3BNick's Avatar
2006 E55
Are you looking for the compact spare the other w211 amg cars have? or just another wheel and tire that will fit but sit in your garage? You could try calling a few salvage yards to see if they have something that works.
Also, If you get the compact spare that requires inflation, be sure to see if they have the 12v air compressor for the spare.
Old Apr 15, 2013 | 09:28 PM
hank55's Avatar
thanks. my car does come with the 12v compressor, i will check all the yards for a w211 spare
Old Apr 15, 2013 | 09:29 PM
Your car should have come with a 12v compressor, jack, and wrench. I also carry a cheap tire plug kit for emergencies.
Old Apr 15, 2013 | 10:32 PM
lowprofile's Avatar
E55
Idk about that, my '04 came with a space saver spare.
Old Apr 15, 2013 | 10:36 PM
hmm..could have been an add-on option then, or a mid-year change ?? There is no room for a spare and the battery is mounted forward in the trunk pan as opposed to on the RH side on the E55's I've seen with a spare
Old Apr 15, 2013 | 10:45 PM
lowprofile's Avatar
E55
That's it then, my battery is on the rh side as well.
Old May 2, 2013 | 11:45 PM
MAN55LE's Avatar
04 E55 AMG
Old May 3, 2013 | 12:20 AM
Toadster's Avatar
2005 E55 AMG
my 05 has one?
Old May 3, 2013 | 11:21 AM
Rafiki's Avatar
2016 AMG GTS
I just got a full size spare I carry around in my trunk , I live in Chicago , POS roads
Old May 3, 2013 | 11:33 AM
novae500's Avatar
W211
Do what i did. Go to tirerack for closeout deals on rims and buy one and tire at same time. I have an OZ superleggera 18 spare in the trunk.
