Fuel smell again , crankshaft *some pics* :(
it's not even been 6 months and this problem again. Last time they fixed the problem it was
as said on invoice "Left side fuel pump seal leaking"
After fixing and 437$ later " Installed new gasket and ring nut completed"
on Invoice says Parts are warranted for 2 years including labor. Can someone from the pics confirm if it's the same part again or it's a different issue this time.??
Also, I got P0335 code- crankshaft position sensor. Can someone confirm if the wire I'm pointing to is indeed that and what is the "screw" called on top of Air filter box ? Two things same day tsk tsk tsk
What is this screw called ? I would need to open it for crank position sensor but I only have star and philips
Is this again just a seal or I need whole new fuel pump this time ?
This is just too much fuel , it's unreal how they don't consider this as a hazard.
If this isn't covered anyway to work on this at home ?
As for the fuel pumps, I never messed with mine...I just never filed my tank all the way to the top.
Any idea regarding what screw is used on the CPS ?
The CPS is held by an inverted torx bolt, can't remember the size though. You need an inverted torx socket to remove it.
I fixed my fuel leak problem by JB weld cover the whole top.
Here's the thread
https://mbworld.org/forums/w211-amg/...k-problem.html
be coming from.
Could that whole pump be pulled out ? any screws holding or what ? and I should be covered
under warranty since it has been less than 6-7 months when I got the dealer to fix it or do you
think it is not as said on invoice "Left side fuel pump seal leaking" that's what the dealer fixed ,
from pictures does it look like more than a "seal" ??
Also which product JB weld did you use?
http://www.jbweld.com/products/surfa...ns/automotive/
the steel one wouldn't be dangerous since it has plugs and everything there ?
Aaron
shardul has a DIY very informative
