Before and After Dyno E55 AMG - South Africa
Old May 3, 2013 | 03:41 PM
S70T5's Avatar
2003 E55 Amg
Hi
Thought I should share my dyno results for anyone who wants to compare before and after mods.
Its a 2003 E55 amg with 105 000km.
Standard, no mods at all. Dyno at flywheel.
Power = 334kw
Torque = 667nm
Removed the 4 cats, installed knfilters and left s55 intake pipe.
Not worthwhile, didnt get much more power.
Power = 339kw
Torque = 689nm
I then fitted a Eurocharged sc pulley and loaded an ec tune as well.
power = 375kw
torque = 742nm
All these readings are flywheel. Went to another dyno which gives wheel power figures
Power = 325kw at wheels
Torque = 697nm at wheels
Old May 3, 2013 | 05:30 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Nicely detailed
Old May 3, 2013 | 11:25 PM
viren.89's Avatar
2004 E55 AMG
so 325 kw at wheels is 435 whp
697 nm would be 515 lb/ft
I am not sure if these are good numbers or not considering all you got is a S/C pulley and tune.
Old May 3, 2013 | 11:55 PM
Manuyc's Avatar
I didn't log much info like you did. I did a lot of work then dynoed mine
Old May 4, 2013 | 03:35 AM
S70T5's Avatar
2003 E55 Amg
It seems about right, based on the dyno graph on Eurocharged's website. Eurocharge state 442hp at wheels for pulley and tune.
If I convert kw to hp
http://calculator-converter.com/conv...calculator.php
325kw = 441 hp
I got 328kw and 684nm on my 1st dyno run, but operator printed the 2nd run. 328kw = 445hp
Whats interesting, is the fact that the 4 cats are not restrictive, had I known, I would not have had them removed as the gains were minimal.
Old May 4, 2013 | 07:29 AM
FinanceMike's Avatar
CLS55
325kw = 441 hp
The manifolds are very restrictive. I picked up almost 40whp by installing Kleemann headers. The rest of the exhaust is very well made by the factory. Removing pieces is mostly sound improvements.
Old May 4, 2013 | 11:03 AM
S70T5's Avatar
2003 E55 Amg
Im waiting on a quote from TNT Exhausts to quote on the headers.
Here is an example of what they made for a c63.
Scroll further down in the post to see the locally manufactured units.
http://www.carforums.co.za/viewtopic.php?f=7&t=46783
Old May 4, 2013 | 11:17 AM
ajm55's Avatar
2006 E55 AMG
I have TNT headers on my 55k. They yielded a 20wkw gain (tested on two dynos) - and that's at Johannesburg altitude. Best value for money mod I've done so far.
Old May 4, 2013 | 12:06 PM
S70T5's Avatar
2003 E55 Amg
AJM55, do you have pics of the headers before install ? Im in Cape Town, was recommended to go with tnt as they do a good job. Can get it made here in cpt but they need the car for 2 weeks to fabricate it. TNT has a template already, which would only mean a 1 day install.
Old May 4, 2013 | 12:20 PM
ajm55's Avatar
2006 E55 AMG
I should have pics pre-installation. Will try to find them. It'll be easier for me to email them so let me have an email address please.
Old May 4, 2013 | 12:44 PM
S70T5's Avatar
2003 E55 Amg
Thanks, pm sent
Old May 6, 2013 | 08:12 AM
S70T5's Avatar
2003 E55 Amg
Got a quote for the headers. The price with fitting equates to about $ 800, would have been less if I was in the same city as the manufacturer.
Old May 6, 2013 | 10:04 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice dyno info and detailed run info.
Looks like SA has several nice custom header fab options.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 6, 2013 | 10:40 AM
chawkins2001's Avatar
2006 E55 AMG
Nice one boet, what part of Cape Town? I am from the Fresnaye-Bantry Bay area and went to Camps Bay High.
Once you get that beast setup, take it up the coast towards Landudno and open that sum b***h up!!!
Old May 6, 2013 | 01:54 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Wow 800$ for a set of Long tube headers?
I want a set too! :-)
Old May 8, 2013 | 03:57 AM
S70T5's Avatar
2003 E55 Amg
I live in Lansdowne. I dont go much to Camps bay side, only when I have to do some work at my bosses house/villa, www.campsbaybeach.net
Crissus, you can fly to Johannesburg, pick up the headers for $ 570, plane ticket should be about $750. Get to see another country for the same amount as buying headers online. Stay for free using www.couchsurfing.org
Old May 8, 2013 | 10:04 AM
KraljAco's Avatar
E55 W211
What's the name of the company who made you that headers?
Old May 10, 2013 | 12:34 PM
S70T5's Avatar
2003 E55 Amg
Headers were made by www.tntexhausts.co.za
Installed headers yesterday, ran dyno today, previous dyno run was done in 3rd gear but different dyno operator on same dyno says it must be done in 4th. Power and torque are both down, and the graph is not smooth.
Power wheel = 303kw
Torque wheel = 673nm
Old May 10, 2013 | 06:36 PM
Crissus's Avatar
Arent those numbers way off?
In the upper part of this thread i read about 510HP at the crank after pulley and tune... I don't know but for my CL 55 AMG thats just 10HP above the stock rating...
Even for the E55, thats just a 34HP increase at the crank.
Stock rating CL55 AMG Kompressor: 500HP (DIN) and 700NM (DIN)
Stock Rating for E55 AMG Kompressor: 476HP(DIN) and 700NM (DIN)
Weren't the smaller SC pulley and EC tune supposed to produce more like 50HP at the crank?
I read multiple times that with smaller SC pulley + Tune, 82mm TB, Headers, looped-rail+550cc injectors, power would be 600HP at the crank.
For your header problem:
You need to get a tune for it adjusted.
Old May 11, 2013 | 08:29 AM
S70T5's Avatar
2003 E55 Amg
The car is after all 10 years old with 105 000km
Stock it made 454 hp at crank, with decat, kn, sc pulley and tune it makes 510 hp at crank. Hard to compare cars with so many variables like fuel quality, compression status of each cylinder, condition of spark plugs, injectors, fuel pump, etc. Over stock its about 13% increase in power.
I just cannot understand why the car is making less power with headers.
I went to another dyno today, to get a dyno run with afr. This is flywheel kw. I however reset my ecu before I did this run, also iat were 15 degrees cel less than yesterday. Although cant compare the 2 dynos, the graph shape is much better.
power = 408kw
3000rpm = 12.8 afr ( -5.5 timing ) - 33 deg cel iat
4000rpm = 12.2 afr ( -10 timing ) - 38 deg cel iat
5000rpm = 11.7 afr ( -22 timing ) - 42 deg cel iat
6000rpm = 11.1 afr ( -15 timing ) - 50 deg cel iat
Old May 17, 2013 | 04:04 PM
S70T5's Avatar
2003 E55 Amg
Found a fault, the exhaust shop removed the coil packs to fit the headers, they mixed up the wiring on one cylinder. I rectified it.
Did 2 dynos runs, one 45 mins after the other, dynotech and jdmworx. Dynotech = flywheel, jdmworx = wheel
Dynotech - 382kw - iat started at 48 deg C, power would have been higher if the fan was used earlier to cool it down.
Jdmworx - 332kw - iat started at 32 deg C, did one run at 50 deg, power was at 328kw.
Graphs are also smoother than last time. Overall got 7wkw more after headers, I think the plugs are old, will get 1 step colder and a new ic pump.
Old Sep 27, 2013 | 06:28 PM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Geepers mate, only 7kw more... That's pretty bleak when MBH is offering money back guarantee with no less than a 40whp increase with just their headers
Old Oct 4, 2013 | 02:46 AM
S70T5's Avatar
2003 E55 Amg
I suppose it doesn't show much gains on the dyno but the car certainly does feel fast. Using a Samsung galaxy gps, shows 0 to 200km/h in 12.7 sec.
Old Oct 4, 2013 | 03:48 AM
C32owner's Avatar
Wow nice,that is moving some.. Well after my poor gains after installing upper pulley and supposedly doing a custom tune I only got 15RWHP gain. So your 7kws is now quite a bargain in restrospect!!!
Old Oct 4, 2013 | 04:34 AM
AutoLuxury's Avatar
2013 GLK 350 2013 GL450
Hmmm those numbers seem a bit off. You will need to get tuned for those headers.
