For those DIYers wanting to cherry pick their engine and reinstall it themselves, here's a ten second tip to facilitate its R+R without removing the hood. The factory gas shocks have an extra two inches of travel in them, the limiters are in the hinges. So to stand the hood on a 90' angle, remove the upper two out of the three hinge-to-hood bolts and let the third lower bolt be the apex. The gas shocks will stop the hood at just short of ninety degrees allowing full access to the airspace above the engine compartment.
I just pinch the hood release in both hinges, do right side first then left.
You don't have to pull any bolts out.
When is your car going to be done? You going to run the 1/4?
You werent kidding when you said shes just sitting lol..
Lol! I just looked closer at the hinge and saw those.
I'll wear my imaginary dunce cap the remainder of the day.
Originally Posted by Yacht Master
I just pinch the hood release in both hinges, do right side first then left.You don't have to pull any bolts out.
Quote:
I'm sure I will want to see what kind of times I can get out of it. Orlando Speed World just sold to a new owner that's making a lot of improvents and it's about ten miles from me. It was a dump before, I haven't run a car in many years.Originally Posted by AKnight55
Quote:
Yeah that's the truth! It's been down about a month, and I've been slammed with work so this has been the side project. I've done a lot of one-off stuff to the engine that I'll detail in a thread as I put it back together for others to learn from. Those kind of things take forever to plan and get right on the first try. Even then some trial and error is necessary.Originally Posted by aghakauve
Quote:
I know how you feel buddy, well if you need anything you have my number!! Let me know if you need any parts.Originally Posted by Sir-Boost-a-Lot
ExploreI do this when all the time, my shocks are starting to fail and they slowly go down to a certain point lol. Plus its easier to clean the engine bay.
