PAS6201 E55 Build Thread
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
The driver side wastegate was finished up yesterday. Finally able to get it in a good spot tucked away.
Are they painting your brake calipers ? Or are they powderrcoating them with the seals and pistons still in? I know the seals will take the heat.. But I hope they were super careful sandblasting around them. All the calipers I've done like that in the past I've covered the whole inside with duct tape so that sand couldn't push it's way in and get caught in the seals. I'm sure they've got it under control though, maybe just wanna give them a glance over before it goes back together.
She is going to be a monster!!!
LOL
Will name the car Michael Myers.
