PAS6201 E55 Build Thread
#606
Former Vendor of MBWorld
If there is a problem then more than likely there will be a code also. I have dealt with similar issues before on other cars. The trick is to know what the ECU is complaining about specifically and tricking it into thinking that it isn't an issue. For example is the ECU complaining that the sc clutch isn't there? Or is it that it isn't engaging? Knowing that determines how you deal with it.
#624
Brabus K8 E55 05
The clutchless guys (Weistec SC, or the Fixed pulley) manage to overcome that, no? EC Managed to get a tune for the fixed pulley and also managed to tune the Weistec SC, so, it can be solved, I am hoping to see new results
