RPM Signal PU for logging
Old Jun 19, 2013 | 10:10 AM
MindBend's Avatar
'05 E55
I'm sure someone's been down this road, so I'm hoping for some specifics...
Want to pick-up an RPM signal for logging purposes. From the docs, "RPM Input. 0-5V, 0-12V square wave, tach signal, primary (low voltage) side of ignition coil, crank, cam sensor."
Anyone have specifics you're willing to share? I've been using OBDII, but it's just too darn slow.
Thanks.
Old Jun 19, 2013 | 10:19 AM
Hulk's Avatar
A Merc
In the ecu box on the drivers side open it up there should be a pink/peach colored wire that will be your tach wire
Old Jun 19, 2013 | 10:35 AM
MindBend's Avatar
'05 E55
Hulk,
PERFECT info for what I needed. Thanks much!
Old Jun 19, 2013 | 10:45 AM
jmb614's Avatar
E55 AMG
I think RPM is C3/Pin 2 iirc, but if you can I would pull from the cam sensor. It's supposed to be less spiky or so I've heard.
TPS is C3/Pin 21
Old Jun 19, 2013 | 01:00 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Here is what you are looking for. From this info you can do MAP, IAT, TPS, and RPM.
Old Jun 19, 2013 | 01:08 PM
MindBend's Avatar
'05 E55
These rock! Thanks...feeling the love here!
Old Jun 19, 2013 | 01:38 PM
Hulk's Avatar
A Merc
Ali that looks familiar lol
Still have it from when you sent it to me
Old Jun 19, 2013 | 02:12 PM
adianaty's Avatar
Hulk - If you can figure out where to get the other half of this sheet I can figure out out how to log your bypass valve ...
Old Jun 19, 2013 | 02:18 PM
Hulk's Avatar
A Merc
Bla bla bla lol
Old Mar 7, 2016 | 10:54 AM
Ronnie Benini's Avatar
Mercedes CLS 63 2008 w219
Tachometer signal 5v fo nitrous window sitch
Do you know which wire in a 2008 cls63 I can hook up to for a nitrous window switch and tach 5v. Will I need an adapter. Thanks.
Old Mar 9, 2016 | 08:24 AM
Hulk's Avatar
A Merc
No, I think they changed the pin out on the NA cars.
