--Mercedes Benz Coolant Thread/Opinions/Thoughts--
Old Jun 27, 2013 | 07:49 AM
berti_00's Avatar
2016 Cls63s AMG
Hey guys i know most of you would say to do oem coolant and what not but there is also guys out there using other stuff so i thought i'd get multiple opinions on our coolant, i know there isnt really much talk about it so maybe we can clear a few things out. I am doing my flush in a few days or so and bought a gallon of Zerex G-05. What do you all think
Old Jun 27, 2013 | 09:00 AM
E55Dimon's Avatar
E63S
It's just coolant..not a big deal. Just try to keep it the same kind or oem. You can put water in there and it'll work theoretically.
Old Jun 27, 2013 | 09:27 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Should be fine. Someone listed the major brand you can buy that just labels it for MB, but been a few years since I saw that thread. I pretty much run distilled water and watter wetter in mine but safer to stick to the specifications from MB.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 27, 2013 | 09:28 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Berti the G-05 is OEM
And yes there is a extender pack in the header tank so that it can last 10 years not sure if you can replace it, I'll find out next year, and no not all antifreeze is the same, I would advise not to use the green antifreeze but you can do a search on that nightmare on any MB forum.
Old Jun 27, 2013 | 10:54 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
That's the OEM coolant. You'll be fine.
Old Jun 27, 2013 | 11:59 AM
berti_00's Avatar
2016 Cls63s AMG
great, thank you very much for the replies, i appreciate it always feel more comfortable hearing your guy's opinions too.
Old Jun 27, 2013 | 01:33 PM
HeissRod's Avatar
On a side note, when I did my HE install, I grabbed a bottle of the G05 on my way to the shop. When I got home that night, I went to put it away and found that I had a half bottle left over from working on my Jeep. Turns out SRT uses the same coolant. Since it's such a relatively unique coolant, I never thought I'd actually have some sitting at the house. Now I have 2 half used bottles on my shelf.
Old Mar 22, 2016 | 11:47 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
I know I'll get beat up for this, but he goes. If i have a car that I've spent a very high amount on let's say after marketing type of stuff, you better bet I'm not going to spend less money on coolant. Just get the OEM! !
Again, to each is own.
Old Mar 23, 2016 | 12:23 AM
HeissRod's Avatar
You bumped a near 3 year old thread just to add an opinion?
Old Mar 23, 2016 | 09:03 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
You acknowledge a near 3 yr old opinion to open your trap!
Freedom of speech!!
Old Mar 23, 2016 | 09:33 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
@HeissRod
First of all, i was doing some research and i wanted to know what the masses were using as for antifreeze fluid.
OEM or another brands nothing more nothing less.
