Q for those who have actually run the mile
Old Jun 27, 2013 | 11:09 AM
jcjmw's Avatar
2005 E55 Wagon
Post Q for those who have actually run the mile
I have a question for those who have ACTULLY put their car through the mile (Mojave Mile, Texas Mile or otherwise). When you ran the mile in your merc:
1. Did you run with your CF front lip?
2. Did you cover/tape over your grill?
Thanks ahead for any response.
Old Jun 27, 2013 | 11:18 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
people usually use painters tape.
During the mile every bit of aero modes help.
I would run the splitter
you dont need to be aggressive in the luanch you can roll off the line and then stab it
Old Jun 27, 2013 | 11:19 AM
SavMan's Avatar
2004 E55K AMG Wagon
I don't have a CF lip and never taped on the 10 runs I have done, I have seen one car lose its CF front lip at 170mph+ and it made a real mess of one of the side skirts.
Old Jun 27, 2013 | 01:20 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
A splitter will increase downforce on the front and actually slow you wayyy down. If you're worried about stability at 160+ then keep the splitter and hope for the best... but I would remove.
I've done it twice, left everything stock up front.
Old Jun 27, 2013 | 11:24 PM
jcjmw's Avatar
2005 E55 Wagon
Thanks everyone for the response!
Old Jul 29, 2013 | 07:39 PM
jcjmw's Avatar
2005 E55 Wagon
Well, it looks like I will be attending the Mojave Mile? Anybody else?
Old Jul 29, 2013 | 08:32 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
1)Tape every crack and seam on the car painters tape.
2)Keep tires aired to normal operating range, lower car as much as possible.
3)Bring lot of ice for trunk tank.
4) Use race fuel or at least mix it in for extra saftey
5) Remove front lip if you can , if not tape up all the cracks and seams on it to keep air out and or from ripping it off.
Oh yeah, this is a big one. Make damn sure you tighten up all your belly pan bolts and if any are stripped, replace them!!!!
Last ,, enjoy the ride my friend!
This vid shows how the car was taped when my wife and I ran the car.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 29, 2013 | 09:24 PM
jcjmw's Avatar
2005 E55 Wagon
CL55 180mph pass at the Texas Mile - October 2010 - YouTube
THANKS!!! Keep those tips comig!!!
Also, did you have a special ECU tune for the mile run?
And, your wife ran +180 but you ran 178.8?
