Back up camera to the nav screen DIY
E63 W211 08, C32 W203 02
Does anyone want a DIY video on how to install a backup camera using *******?
I'm going to *******.com to install a backup camera to my e63. They will use my car for a DIY video.
yes sir - share the wealth
http://*****************/MERCEDES-BENZ_E-CLASS_03-08.aspx
this the one you getting - i wonder since i had aftermarket video headrests added if i have the ability to tie in the rear camera.
How it works:
NavRGB 2.0 is a new generation of navigation video interfaces that add video capabilities to MERCEDES-BENZ vehicles with factory installed navigation system, or with color information screen.
NavRGB 2.0 does not replace or add a factory navigation system; it creates additional video inputs for the factory installed navigation system or color information screen.[/I][/I]
How it works:
[QUOTE=baldmike73;5696061]yes sir - share the wealth
I will ask them if we can get a group buy.
How it works:
How it works:
Lets pretend that I am a 5 year old. I install and hook up my rear view camera to this thing (http://*****************/MERCEDES-BENZ_E-CLASS_03-08.aspx$) and then hook that thing up to the back of my OEM merc nav/radio. That sounds so easy. Did I get that right? I hope so, b/c that would be great!
$600? If you don't have HK sound system (which makes things dramatically more complex and expensive), then just do NGT2.5 retrofit for roughly same price and then you have both.
Or just dump the factory head unit and get any after market (which work with any rear view camera).
I have developer mode and I can only read the settings but can't make any changes, I think my star is 09/2011. It's driving me nuts that I can't enable it.
Do you get into command through w164 or r171?
1 Post
2006 E55, 1997 Mustang Cobra Conv
Sidebar: How much did it cost you to do the retrofit with the new command & I assume the 2 new amps / wiring harness? I was headed in that direction until I found it would be easier/cheaper/better tech to go aftermarket. I haven't pulled the trigger yet though...
I got a great deal on the command last nov for $500 and then started collecting the rest of the parts one by one, found the hk locally for $200, the sub amp and hd radio module from potomac german auto for $139 each shipped and harness was $300. So if you take your time you can find deals for sure.
Start with this. he's local to you, make him an offer:
http://www.ebay.com/itm/2009-MERCEDES-COMAND-NAVIGATION-W211-W219-E350-E550-E63-HDD-NTG2-5-DVD-VIDEO-/111108738929?pt=Car_Audio_Video&hash=item19de98cf71&vxp=mtr
