Need some advice
Saturday berti and I dynoed my car again
Last Dyno 482 whp and 502 torq no humidity
Mods
X pipe
Sc pulley
Tune
Split cooling
Python tubes
Tb bore and grind shaft
Added mods
82 tb
Cabreno cf air box
And dynoed 485 whp and 532 torq with a lot of humidity. Plus diff Dyno
Plus the tech said way to rich at WOT. He said it need to be more like 10-11 AFR from 4k to 65k RPM
Check the graph and video
He started in 4th gear
LINK TO THE VIDEO. PLEASE CHIME IN
http://s21.photobucket.com/albums/b2...01085BF66B.mp4
Mods
X pipe
Sc pulley
Tune
Split cooling
Python tubes
Added mods
82 tb
Cabreno cf air box
You cannot compare two different dyno results on two different dynos on two different days...Also, I know you won't want to hear this but if you had a lighter rim & tire combo, you would see much better numbers....Also, headers will really help your hp numbers in the 3000+ rpm range.
06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Get the Kleemanns for $995 from Cory. Have Nemo install them and go cat-less. You'll be sitting about 30-35whp more than you are now. You'll have a solid 500whp car with a mild tune, probably 515-520 with an aggressive tune.
