82mm TB months of problems
Rating: Thread Rating: 3 votes, 5.00 average.
Old Nov 3, 2013 | 10:37 PM
  #101
E55Greasemonkey's Avatar
This place is a joke.
The gas pedals have been known to go bad...Hmm..That would be interesting to replace yours, or can you log the gas pedal sensor? I wonder if your pedal sensor is bad...maybe it is not an issue with the stock 74 TB, but once the 82 is there..that small hiccup which may go unnoticed on a stock car, would cause a problem here..Starting to make sense about the MAP code...the ECU sees that MAP pressure shoot up from nowhere, and faults the sensor. Just thinking aloud here, bear with me..
Old Nov 3, 2013 | 10:39 PM
  #102
Originally Posted by Denroll
Thing about that TPS going full WOT... I am not going WOT. Only giving it less than 1/4 throttle.
Knowing how the 82TB increases the response of the engine according to pedal position...example, 82TB, press the pedal 1/4 is like pressing the 74mm 1/2 or more...what if your pedal sensor had a small hiccup..it is now exaggerated by the 82mm, enough to feel, and enough to set a code. Whereas this small "glitch", maybe only a fraction of a second would not be noticed stock??
Is there anyone nearby with an 82mm with no problems that can swap gas pedals with you to test? It's an easy swap, about 5 minutes.
Old Nov 3, 2013 | 10:42 PM
  #103
Can you add injector PW to your logs? I suspect you'll see no increase during the hiccup. Can you log gas pedal position?
Old Nov 3, 2013 | 10:49 PM
  #104
My instinct says your TPS going open is the clue we've been looking for. As I said before, this has always sounded like a vacuum leak problem to me, obviously a lean condition, and if your TB is flicking open even for less than a second..What we don't know is if the TPS is cause or effect...Is the ECU opening the throttle because it thinks the engine is stalling?
Old Nov 3, 2013 | 10:56 PM
  #105
Aww crap..........just looked at the logs and didn't realize the first line hiccup shows the TPS Ok. So let's start over.
I see it's going lean though, which we know. Can you log the injectors at that same moment? We need to find out why it's going lean...is it cutting fuel (less injector PW) or is there more air coming in somewhere. Maybe log the EGR too.
Old Nov 3, 2013 | 11:37 PM
  #106
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by Shifter
Wait I'm pretty sure you were having an issue since the tb install, remember reading a thread about it ?????
actually it had nothing to do with the TB it was my intake, it was catching into the butterfly because my intake inlet was 74mm and it was slipping somehow and hitting the inside
Old Dec 9, 2013 | 12:54 AM
  #107
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
Hi All - I'm getting ready to install the EC 82mm TB and 550cc injectors and have a few questions:
First, the 82mm TB I got from Eurocharged has the throttle blade oriented in the opposite direction from the stock TB. I assume this is an Audi TB and not MB? Do I need to reverse the blade or something? Will this difference in orientation have any adverse effect on performance or driveability?
Second, I was told this is a plug and play kit, but on the 82mm, there's no port for the PCV hose that plugs into the port on the stock TB. Where am I supposed to connect the PCV system, I don't want to vent to atmosphere. Should I drill/tap the 82mm TB and install a barb for the OEM PCV fitting or connect the stock PCV plug somewhere else?
Third, my understanding is I need to do a simple pin swap on the factory male plug as per the EC instructions. Please confirm this is necessary and does this require any special tools or soldering?
Last, I have 5 new gaskets from the dealer pictured below. Are there any other gaskets, O-rings or seals I need before I tear into this project?
My car is running super strong right now and I'm nervous about this install as I've heard of other members having surge/hesitation issues on tip-in with the 82mm units. Hopefully, it's a tuning issue and after Eurocharged reflashes my car for the shorty headers, 82mm and 550cc injectors, it'll drive perfectly as it does today with no trouble codes.
Any guidance or things to lookout for would be appreciated. Thanks.
Old Dec 9, 2013 | 01:02 AM
  #108
mrweelr's Avatar
Old Dec 9, 2013 | 07:15 AM
  #109
berti_00's Avatar
2016 Cls63s AMG
As far as gaskets looks like you got everything there. I personally have never seen a tb like that before so I couldn't help you on that, since I use oem and it's flawless, great power
Old Dec 9, 2013 | 08:36 AM
  #110
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
When I installed 80mm Kleemann TB ,they sent me a new y pipe with a 90 deg hose barb for the vent hose you're talking about ,because the 80 mm TB they sent me did not have vacuum port like yours pictured I have since switched to MB 82mm TB,I am now looking to go to 90 lol,no problems with either 80 or 82mm TB,s however they were Mercedes TB
Old Dec 9, 2013 | 09:37 AM
  #111
cnterline's Avatar
The TB number I have is Mercedes 2731410325
Old Dec 9, 2013 | 03:04 PM
  #112
mrweelr's Avatar
Interesting. I think I'm going to pass on installing this. Looks like I should have done more research before jumping on this group buy earlier this year. Thinking about selling this 82mm TB now since it appears to not be an MB OEM unit and don't like the fact that the throttle blade is oriented differently plus no PCV port. Can I unbolt this TB from the EC adapter plate and bolt on an OEM MB 2731410325 unit in its place without any issues? If anyone has a new MB 2731410325 TB for sale, please PM me. Thanks.
Old Dec 9, 2013 | 03:23 PM
  #113
ajm55's Avatar
2006 E55 AMG
Contact Bertie 00
Old Dec 9, 2013 | 04:00 PM
  #114
berti_00's Avatar
2016 Cls63s AMG
if you want one or anyone wants one i have 2 more OEM T/B's
Old Dec 9, 2013 | 05:09 PM
  #115
mrweelr's Avatar
Old Dec 9, 2013 | 05:54 PM
  #116
berti_00's Avatar
2016 Cls63s AMG
Are they new or used? PM sent!
they are almost like new honestly with 15k to 30 max on them...
Old Dec 9, 2013 | 06:40 PM
  #117
The55's Avatar
2006 Slk55
How much for the throttle body?
Old Dec 11, 2013 | 10:34 PM
  #118
mrweelr's Avatar
Can someone confirm whether the bolt patterns between the Audi 82mm and MB 82mm TBs are identical? I'm trying to determine if I can swap an MB S550 82mm throttle body onto the Eurocharged snout and adapter plate which currently have an Audi 82mm TB bolted on. Anyone?
Old Dec 11, 2013 | 10:50 PM
  #119
black06c230's Avatar
mgLipGD
So much for plug and play?!???
Old Dec 14, 2013 | 09:02 AM
  #120
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Can we go back to topic, which is the hiccup issues? :-)
Are there any news yet?
Part of the discussion also shifted to this topic: https://mbworld.org/forums/w211-amg/...ts-pics-5.html
Shouldn't anyone make a poll or something so the users with or without hiccup issue can vote on which year their cars are built and wheter is a OEM TB or a Audi one (in case of the infamous 82mm TBs) ???
Old Dec 14, 2013 | 07:22 PM
  #121
Denroll's Avatar
'06 E55
We've already ruled out the Audi/Porsche TBs as the culprits. People have had the hiccup with the larger OEM Mercedes TB and I have it with the BBK 90mm.
Old Dec 14, 2013 | 10:27 PM
  #122
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
You had the problem with the 82mm as well, and it stayed after you upgraded to the 90mm, am I right?
Old Dec 15, 2013 | 12:40 AM
  #123
ajm55's Avatar
2006 E55 AMG
Correct. I wasted money replacing the non OEM 82mm t/b with an OEM 82mm t/b in the hope that doing so would resolve the issue. It did not.
A caveat to the guys experiencing the problem (hiccup mode) - I'm almost certain that it resulted in my engine blowing. Although I wasn't logging AFRs when my engine blew, I have now on 3 occasions since installing the new motor repeated the trip undertaken the day my engine blew and without fail, on each occasion, hiccup mode has manifested within 2km of where the failure occured.
Old Dec 15, 2013 | 06:33 AM
  #124
Crissus's Avatar
Right, i understand.
So people came with other possible causes, one that is that the ECUs year might have something to do with it. And in order to just get closer to a solution, i think such a Poll would be a very good idea.
Old Dec 15, 2013 | 06:53 AM
  #125
Robert AMG's Avatar
Cls63 & C32
Is there anyone having the hiccup on stock injectors ?
I am suspecting the bigger injectors.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
