2007 Mercedes E63 Cold Start Ticking (video)
Subscribe
Aug 5, 2013 | 06:10 PM
2007 Mercedes E63 Cold Start. Is the ticking I am hearing OK ? Can somebody please post video of your engine cold start. Thank you!
http://www.youtube.com/watch?v=aBI7k...ature=youtu.be
Reply 0
Aug 5, 2013 | 06:12 PM
sounds okay to me
Reply 0
Aug 5, 2013 | 06:24 PM
What is making that ticking sound ?
Reply 0
Aug 5, 2013 | 07:40 PM
Sounds normal to me as well. I don't even really hear what I would define as a tick.
Reply 0
Aug 5, 2013 | 08:07 PM
i thought mine had ticking, fresh oil change and no more sound
Posted from Mbworld.org App for Android
Reply 0
Aug 5, 2013 | 08:19 PM
Sounds very normal
Reply 0
Aug 5, 2013 | 08:46 PM
When you first crank it, it sounds like the valve train is dry, but gets lubed very quickly.
The sounds you are hearing when you were moving the camera all around sound very normal to me. Typical valve train and injector noise.
The older engines, like in the mid 60s had solid lifters and so on they sounded like a sewing machine when running.
G
Reply 0
Quote: i thought mine had ticking, fresh oil change and no more sound
Ironic that a guy posting about his 55 engine, which is so very different than the M156, actually has a little bit of truth.
I have been having problems with the oil filter element not staying connected to the cap when removing. The result is a messy oil spill because the oil filter element lifting with the cap releases a valve at the bottom of the housing to allow the l to drain. Previous 2 times I had a mess. So next time I made sure it lifted out with the cap. Took a couple tries. Effectively "I messed with it". So somehow the valve did not seat closed properly for whatever reason. This allowed the oil to drain and the hydrolic cam adjusters took 2-4 seconds to pressurize and operate properly.
Oil analysis showed no change in engine wear. The next oil change I did not "mess with it". Noise gone immediately.
I recommend an oil analysis. Blackstone labs. You can search and find my results.
Reply 0
Explore
Aug 5, 2013 | 09:59 PM
Can somebody please make similar video of E63 engine starting and post it here. FYI. My engine has 98k and oil was changed 350 miles ago. Thank u in advance !
Reply 0
Aug 8, 2013 | 12:08 PM
Star Bulletin from 2009 attached to this post : https://mbworld.org/forums/5445643-post20.html
The PDF contains mp3 recordings of problematic valve/cam adjuster sounds
Reply 0
Aug 8, 2013 | 01:40 PM
Starbrite thank you very much for the PDF. But somebody PLEASE make a quick video off your engine running on start up
Reply 0
Aug 12, 2013 | 07:18 PM
Reply 0
Aug 12, 2013 | 07:21 PM
Reply 0
Subscribe
Currently Active Users (1)
