My project at work (M156 Engine tick, noisy lifters)
Old Aug 9, 2013 | 06:55 PM
mb techman's Avatar
CLA45
Old Aug 9, 2013 | 07:01 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
I know someone in Sacramento whos got the same issues with their S63. Lifter noise also. I think they got it fixed but I never asked or followed up.. POST MOAR PICS!!!!!!!!!!!!!!!!
Old Aug 9, 2013 | 07:02 PM
mb techman's Avatar
CLA45
Old Aug 9, 2013 | 07:54 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
That's how I bought my first car for $500. A new camshaft and lifter later and I had a perfect 5 year old car.
Old Aug 9, 2013 | 09:36 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
common to all 63s
I have 07 E 75K and no noise ...YET...
Anything we can do to prevent this ???
Dam..my JDM Mazda has 268K oil change like when ever and no ticking...
100K car and this BS..
Old Aug 10, 2013 | 06:24 PM
statepkt's Avatar
2007 E63
Thats probably what my engine looks. I had loud ticking and finally one of my head bolts broke as well. I will have pictures as well later when the job starts
Old Aug 14, 2013 | 08:14 PM
mb techman's Avatar
CLA45
Old Aug 14, 2013 | 10:00 PM
Shifter's Avatar
E55, SL63, ML550
I love how easy the 156 is to work on.
Old Aug 15, 2013 | 12:45 AM
baldmike73's Avatar
just took my 08 E63 in the shop the other day - (thank god for warranty) - upon start up very loud ticking sound - immediately turned off car and hopped in the 55 and went off to the office. Of course my wife took the car to the dealership and heard the ticking the whole way and now they can't replicate - WTF? at least i have warranty until next December
Old Aug 24, 2013 | 10:59 AM
FREDC43AMG's Avatar
AMG
Well...sadly the poor quality cams thing is not a rumor. My 2007 E63 (80,000Miles) was having some minor ticking clicking sounds and began to go much louder and was always present. You can clearly notice the wear on the second cam lobe now, even the other cam is starting to wear.
Old Aug 24, 2013 | 11:07 AM
statepkt's Avatar
2007 E63
^I take it that you still have the original valve tappets/buckets? Mercedes updated the design (SLS63 style) to help resolve this issue.
If you are replacing the CAMs you should replace those as well
Old Aug 24, 2013 | 11:23 AM
FREDC43AMG's Avatar
AMG
We will order Both cams and all lifters since we are in there... Ill verifiy if these parts have been updated.
Old Aug 24, 2013 | 12:02 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
mbtechman, in your last pic on the cam front view with the adjusters removed, what is the fastening device other than the main bolt at the front. There seems to be no positive locking device ie a flat area, or pin or key just showing the round end of the cam? Notice the 5 small circle contact areas on the end of the cams but is that all there is these contact areas and the torque on the adjuster bolt? Is that all there is, what am I not seeing?
Old Aug 24, 2013 | 12:22 PM
Critter's Avatar
MBtechman
When you removed the intake cam did you mark it previous to removal and when doing so the MB cam bracket would have been taken off, is this correct. So when the cam is reinstalled you tighten all fasteners then rotate the cam or cams to your previous cam mark and then reinstall the MB cam support, is this correct.
Old Aug 24, 2013 | 02:03 PM
Critter's Avatar
I take it is a customer car, with work being done at a dealership, are you replacing all buckets and cams and what is your take on the head bolts. If you are right there would you do the bolt for bolt replacement or is it not warranted or possibly money related?
When replacing cams is there a special lube applied to the new cams and buckets to ease break-in?
Old Aug 24, 2013 | 10:55 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
I have been looking for a post like this for 3 years
I also have to replace the lifters and 2 adjusters
I know I need the 2 tools you show . Do I need the 3rd tool that I see in WIS
That goes in front of the adjusters like a plate?
And what do you use to keep the tension in the adjuster( some sort of pin)?
Erick
Old Jan 1, 2014 | 01:40 AM
mjcarlin's Avatar
08 C63 AMG, 08 ML550, 07 F150, 02 Subaru Legacy, John Deere TLB
Originally Posted by mb techman
Why did you remove the adjusters/drives from the cams?
Old Jan 6, 2014 | 09:58 PM
Weee55's Avatar
06 E55 (RIP), 07 E63, 2018 C63S
Anyone know how much this would cost to fix without warranty? My E63 ticks once in a blue moon at startup, but it always goes away once the car is warmed up.
Old Jan 7, 2014 | 12:11 AM
seven11's Avatar
BMW 7 series
i am looking for an s63 and this makes me want to not get it
also curious about the cost without a warranty.
Old Feb 10, 2014 | 07:11 PM
mb techman's Avatar
CLA45
Old Feb 10, 2014 | 07:23 PM
mb techman's Avatar
CLA45
Old Feb 10, 2014 | 07:24 PM
mb techman's Avatar
CLA45
Old Feb 10, 2014 | 08:54 PM
Critter's Avatar
@mb techman,
Thank you for the information, would it be possible to get a picture of the other tool required to hold the cams at the rear of the head.
Just wondering why there is no lube other than oil to the mating surfaces of the lifter and cam face. Break in lube is not required on new parts?
Old Feb 10, 2014 | 09:16 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
can someone post a vid of this noise ?? i got 2010 c63 not sure what this noise sounds like....
Old Feb 11, 2014 | 09:37 AM
mb techman's Avatar
CLA45
