New Front Brakes done @ Dealer
Old Aug 16, 2013 | 10:46 AM
AMG_Guy's Avatar
CLS55
Had my front brakes (pads+rotors) replaced at dealer.
MUCH more stopping power, but I notice when braking from 60mph+ I get a shake front the front almost as if rotors are warped. Normal? Do I need to brake them in?
I had a balancing done (road force balance) at the same time.
Old Aug 16, 2013 | 10:58 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
ya u should drive easy for abit
berti_00's Avatar
2016 Cls63s AMG
+1
Old Aug 16, 2013 | 11:00 AM
AMG_Guy's Avatar
CLS55
Awesome....thanks!
Old Aug 16, 2013 | 11:13 AM
C_DirtyTwo's Avatar
a land yacht.
Definitely drive easy, but that does not sound normal.
Old Aug 16, 2013 | 11:16 AM
AMG_Guy's Avatar
CLS55
I was kind of thinking it didn't seem normal...not sure if I should mention it to them or not.
Old Aug 16, 2013 | 12:02 PM
Toadster's Avatar
2005 E55 AMG
I hate to ask how much that cost...
Old Aug 16, 2013 | 12:04 PM
AMG_Guy's Avatar
CLS55
Wasn't too bad...I was expecting more.
Old Aug 16, 2013 | 12:10 PM
C_DirtyTwo's Avatar
a land yacht.
I would take it back for sure. I changed my pads and rotors myself and never experienced this.
Old Aug 16, 2013 | 12:16 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
You need to properly break in the rotors and pads. Hard braking will **** your **** up and good luck getting the parts warrantied when they are a solid purple color from over heating..
BTW how much did this cost? I just got a quote on the pads and they have each front rotor for $138 (cheapest I have seen anywhere).
novae500's Avatar
W211
Since dealer did them, ask the tech to take out and you ride along to show the shaking/pulsating. Should bed the brakes in correctly.
Old Aug 17, 2013 | 03:30 PM
FromM3toAMG's Avatar
07 E63
just take the car back. why even waste time asking on here, call ur service adviser. But you really shouldn't be doing any hard breaking until the pads AND rotors are beaded in properly.
Old Aug 17, 2013 | 03:31 PM
07 E63
I donno but i paid $500 just in labor to have my front and rear pads and rotors replaced lol $2100 in parts and fluid for all OEM.
Old Aug 17, 2013 | 07:22 PM
pnoyworx's Avatar
10 E63, Sold -07 E63
The vibration is not normal, but proper bedding is needed, and that does require a lot of HARD braking. After bedding, you don't have to worry about taking it easy at all. Brake all you want. Just don't do a hard braking session then come to a complete stop with the pedal down, after a series of hard braking, make sure you allow a short time for the brake to cool down before a complete stop.
Old Aug 17, 2013 | 07:35 PM
211.076's Avatar
2003 E55
If they are factory pads and rotors (and I'm guessing they are, being that they were replaced at the dealer), Mercedes-Benz specifies not to perform and special bedding process when the pads and rotors are replaced. Normal stop and go driving is all that is required.
Old Aug 18, 2013 | 12:53 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
take it back. This is not normal.
Rotors might be wrap and need replacing
Old Aug 19, 2013 | 12:23 PM
Quadcammer's Avatar
96 and 08 911 turbos
jesus, this thread is painful to read. Its like only 2 people know how to bed brakes.
rotors may be warped, hub flange may be warped or have corrosion/burrs, etc that keeps the rotor from sitting flush.
go back to the shop.
Old Aug 19, 2013 | 12:35 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
If guys would just drive the car in a semi normal way there would be no need to "bed" the brakes. Easy braking over a week or so and the brakes will last a long time. By easy it is not stated to go from 60 miles per hour to zero just to test the new brakes, get real. Every new car sold does not come with brake bedding instructions. Just drive it easy for a while and the brakes will work properly.
Take it back to the dealer and go with the tech on a test drive to diagnose your issues.
Old Aug 19, 2013 | 12:42 PM
AMG_Guy's Avatar
CLS55
Yeah I'm taking it back to them so they can look at it, definitely not right. I don't get how the new rotors could be warped in a week of driving, lol.
