Put the gates HD 505 belt on tonight...
Old Aug 22, 2013 | 10:06 PM
Toadster's Avatar
2005 E55 AMG
Originally Posted by Shifter
Is that belt shorter than factory?
yes about 1/2 inch: 505 vs 510
http://www.gates.com/oreilly/PDFs/SizeListings.pdf
Old Aug 22, 2013 | 10:45 PM
Toadster's Avatar
2005 E55 AMG
ok - you can really hear it in this video, much better HD camera
Old Aug 22, 2013 | 10:51 PM
berti_00's Avatar
2016 Cls63s AMG
sounds beast
Old Aug 22, 2013 | 10:55 PM
Toadster's Avatar
2005 E55 AMG
Originally Posted by berti_00
sounds beast
maybe i'm just paranoid?
the technicians at the MB garage noticed the sound - maybe just more noise from the aluminum pulley? hmm....
Old Aug 22, 2013 | 11:06 PM
Lawrence1's Avatar
2011 G55 + others
Sounds like a noisy bearing... possibly one of the idlers. Take the sc belt off and start the car to check if noisebis still there. If its still there move on to the other belt and do the same. This should help you narrow it down
Old Aug 23, 2013 | 12:16 AM
Toadster's Avatar
2005 E55 AMG
yah, i guess that is possible - would expect more 'chirps' with the bearings, but who knows, I'll have to give it a few tests...
Old Aug 23, 2013 | 01:37 AM
  #32
ghettoroadster's Avatar
e55
Originally Posted by Toadster
did she feel any tighter?
Old Aug 23, 2013 | 10:08 AM
  #33
Toadster's Avatar
2005 E55 AMG
nope, the tensioner moves WAY more than I thought, had zero issues getting the belt on
Old Aug 23, 2013 | 11:16 AM
  #34
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
I am thinking it's because the belt is alot tighter. Maybe try swapping the old belt on and see if the sound is still there.
Old Aug 23, 2013 | 11:21 AM
  #35
Toadster's Avatar
2005 E55 AMG
Shardul's suggestion was even 1/2 inch tighter with the K080496HD
stock is 510 and I put on the 505
I'll do another try later today without the S/C belt
Old Aug 23, 2013 | 01:36 PM
  #36
Critter's Avatar
07 E63 + 07 CLK63CAB
Initially thought the noise was the idler beside the charger pulley , but when you shut the car off at the end of the video it looked like the bolt was still turning and so was the noise being there also. Get someone to shut off the running engine while you watch that bolt at the end of the supercharger.
Old Aug 23, 2013 | 05:01 PM
  #37
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Looks good and sound good
Old Aug 23, 2013 | 05:19 PM
  #38
Toadster's Avatar
2005 E55 AMG
interesting at :38-:40 you see the bolt spinning...
is this normal operation? I'd assume yes as you really wouldn't want the S/C to stop really hard
Old Aug 23, 2013 | 05:22 PM
  #39
Critter's Avatar
Manuyc, how can you say it sounds good, listen closely and watch when the belt stops at the end of the video (38 seconds) the sound continues until the bolt stops. I have a coffee bean grinder that is quieter than this noise.
Old Aug 23, 2013 | 05:26 PM
  #40
Critter's Avatar
Sorry guys,
I do not have one of those spinney things on my engine, but is there a bearing inside of the clutch, if yes then it is on the way out.
Old Aug 23, 2013 | 05:36 PM
  #41
Toadster's Avatar
2005 E55 AMG
Sorry guys,
hmm - the clutch was new with the pulley - not saying it can't go bad, but it's been ~14k miles
Old Aug 23, 2013 | 05:46 PM
  #42
Critter's Avatar
Toadster, Just trying to help, if you have a mechanics stethoscope put it on the end of the charger casing and then start then shut off the engine as in the video, now listen to the vanes and clutch slow to a stop, this noise I believe will be the clutch bearing or there is no oil in the charger housing. The new belt being shorter could be putting a little more stress on the bearing which would change the bearing load. If you remove the belt and spin the clutch itself you may also hear a bearing noise, in this case put the scope on the charger clutch bolt and spin the pulley. Good luck, better to replace the bearing instead of having it come loose at speed.
Old Aug 23, 2013 | 06:00 PM
  #43
berti_00's Avatar
2016 Cls63s AMG
thats what she said aighhhht
Old Aug 24, 2013 | 08:59 AM
  #44
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Noisey Belt
Take a new un-wet Bar of Ivory soap. With the engine Idling , Run the bar of soap up against the grooved side of the belt just before the Blower pulley. Push it to the grooved with some pressure . If the Noise quiets down , Then the belt needs some break in time. I find alum Pulleys tend to be a-bit noisier during break - in / seating time , than Steel . It will quiet down .
Cheers _PTEngineering
Old Aug 24, 2013 | 08:44 PM
  #45
Critter's Avatar
PTE, Just what is that noise at 38 seconds after the engine and green belt have stopped, soap will not correct that sound, ever.
Old Aug 25, 2013 | 05:32 PM
  #46
PTE's Avatar
PTE
Say What
That is the noisy *** bearing in the Driven pulley on the front of the Kompressor I you watch real close , it is in time with the engine And after the engine stops running the Kompressor is still rolling and there is the noise to go with the rotating shaft. you got a sharp eye. I was going on the fact that he noticed the noise after the belt change , but it was not there for the belt change?
Old Aug 25, 2013 | 06:09 PM
  #47
Toadster's Avatar
2005 E55 AMG
So bad bearing.... Dang. At least not too expensive- who has a spare? :-)
Old Aug 25, 2013 | 09:35 PM
  #48
Critter's Avatar
Well guys. it is always a good day when you find the problem in the driveway and not fifty miles from home in the dark of night.
Good luck with the bearing change, if when you have the belt off spin the idler beside the charger pulley with your finger, if it spins for quite a while then change it also, call it preventative maintenance.
Old Aug 25, 2013 | 10:15 PM
  #49
berti_00's Avatar
2016 Cls63s AMG
that should have not gone bad in such low mileage usage... my stock pulley had 70k plus and i dont think it was never changed and it was smooth as a babys bottom
Old Aug 25, 2013 | 10:17 PM
  #50
AMG E Power's Avatar
E55 amg
+1 I was thinking the same exact thing. You might want to contact who u bought it from to see if they can help .
