Put the gates HD 505 belt on tonight...
Old Aug 21, 2013 | 11:23 PM
Toadster's Avatar
2005 E55 AMG
Nice green belt
It took about 2 minutes, can't believe the dealer charges for this...
My s/c seems pretty noisy on the snout... The dealer even noted the noise the last time in the shop
Any ideas on noise?
Old Aug 21, 2013 | 11:25 PM
berti_00's Avatar
2016 Cls63s AMG
tod i had that belt sitting in my trunk i could of hooked u up
Old Aug 21, 2013 | 11:27 PM
Toadster's Avatar
2005 E55 AMG
dang, no worries - I got the Gates K080505HD V-Belt $32
my old one didn't look bad but I've got at least 15-18k on it so I swapped...
17mm wrench and a really thin allen wrench and 2 minutes DONE!
the other drive belt looks to be a real PITA though...
Old Aug 21, 2013 | 11:44 PM
layzie12g's Avatar
2008 Mercedes Benz E63
They are both ultra easy.
Old Aug 21, 2013 | 11:54 PM
Toadster's Avatar
2005 E55 AMG
I have the drive belt, just ran out of daylight...
FYI - from the DIY thread for those of you wanting to find it the easy way
Serpentine Belt DIY by: Clive
https://mbworld.org/forums/showthread.php?p=2922396
Supercharger Belt Replacement by: kompressed55
https://mbworld.org/forums/w211-amg/239591-supercharger-belt-replacement.html
and a video
Old Aug 22, 2013 | 12:15 AM
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
I put this same belt on a few weeks back it is sooooooo tight.
Old Aug 22, 2013 | 12:27 AM
Toadster's Avatar
2005 E55 AMG
tight - as in cool looking, right?
I thought I'd have a heck of a time stretching the belt onto the pulleys like it was so much smaller but the tensioner moves a hell of a lot when you wrench it
Old Aug 22, 2013 | 12:28 AM
Toadster's Avatar
2005 E55 AMG
anyone have ideas why the S/C may be noisy? I need to shoot a video or something...
Old Aug 22, 2013 | 01:34 AM
Max.H's Avatar
E55
What does it sound like?
Old Aug 22, 2013 | 07:51 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
When mine was making a weird noise it was because the smaller SC pulley's spring had cracked and the pulley was grinding up against the magnet plate.
Might wanna check yours in case that's the problem
Old Aug 22, 2013 | 10:49 AM
AMG E Power's Avatar
E55 amg
post a vid of it toad
Old Aug 22, 2013 | 10:51 AM
Toadster's Avatar
2005 E55 AMG
dang, I hadn't thought of that but when I checked this morning, I don't see any cracks... here's a short video
Old Aug 22, 2013 | 12:42 PM
Toadster's Avatar
2005 E55 AMG
bump - any thoughts? everything seems true and no wobbles
Old Aug 22, 2013 | 12:45 PM
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
It sounds fine to me. Mine sounds a bit worse. Was thinking of making a thread on it.
Old Aug 22, 2013 | 01:17 PM
Toadster's Avatar
2005 E55 AMG
Hmm - maybe a fluid change is in order?
Closer pic - things look ok (to my untrained eye)
Old Aug 22, 2013 | 01:46 PM
E55 amg
cant u just swap it out for a new one if its making a horrible noise ?
Old Aug 22, 2013 | 01:49 PM
Toadster's Avatar
2005 E55 AMG
swap out the supercharger?
Old Aug 22, 2013 | 02:02 PM
Tech-Tune's Avatar
It sounds like it's engaged?
Old Aug 22, 2013 | 02:11 PM
Toadster's Avatar
2005 E55 AMG
I need to get another vid revving, was the only one home this morning so I couldn't do the camera and rev at the same time
Old Aug 22, 2013 | 02:20 PM
berti_00's Avatar
2016 Cls63s AMG
that belt looks pretty until it gets dirty and tood i cant believe you still don't have the idler pulley kit
Old Aug 22, 2013 | 02:22 PM
E55 amg
no toad, the S/C pulley
Old Aug 22, 2013 | 02:29 PM
Toadster's Avatar
2005 E55 AMG
LOL
I don't see why the pulley would be adding to the noise, bearing looks solid - maybe a spring is cracked underneath the pulley where I can't see?
Old Aug 22, 2013 | 02:50 PM
GunMoto's Avatar
EG8 | E46 | W211
^Nice new sig Toad!!
Old Aug 22, 2013 | 04:23 PM
Toadster's Avatar
2005 E55 AMG
Old Aug 22, 2013 | 09:19 PM
Shifter's Avatar
E55, SL63, ML550
Is that belt shorter than factory?
