Old Jun 24, 2015, 01:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Air Intake and Exhaust Guides
Print Wikipost
90mm Throttle Body install with parts/pics
Old Sep 18, 2015 | 09:16 AM
  #226
Roverron's Avatar
ML63
I'm surprised that no one has used spacers to lift the S/C to put a larger inter-cooler under there. How much room do you need to get a worth while improvement?
Old Sep 18, 2015 | 11:42 AM
  #227
Denroll's Avatar
'06 E55
I remember reading an old thread on here where someone was going to make some big ol' spacers to do that, but I don't know if it ever materialized.
A little bit of extra space seems like it would help quite a bit, even with the stock i/c. Maybe rig up some flat ducting that mounts under the hood right behind the grill and channels a little airflow in that general direction for some extra help.
Old Sep 18, 2015 | 01:40 PM
  #228
JoeNobody's Avatar
Mercedes
There's not a lot of extra space under the hood. Would need to measure, but it seems like raising it up an inch might be all you could get, and that's not a huge difference. Factoring in the work to put in a taller inter cooler, and the returns on the work seem low.
Old Sep 18, 2015 | 01:48 PM
  #229
Hulk's Avatar
A Merc
A friend from this forum did put a bigger IC and at the end of the day when the motor gets hot it made no difference
Old Sep 18, 2015 | 03:11 PM
  #230
Roverron's Avatar
ML63
i was thinking to even bump up the hood like a CTSV or BMW. with a larger cooler i thought there would be a lot better gains.
Or even if some one could get the top mounts done with today's pumps
Old Sep 18, 2015 | 03:23 PM
  #231
JoeNobody's Avatar
Mercedes
Top mounts have been done before, but as far as I know nobody has achieved very good results.
Figuring out the air intake is also an issue, unless you just stick a mushroom filter on the throttle body and have it suck in hot air. MKB did a pretty nice looking top mount with air filters, but they also charged a small fortune for it.
Old Aug 22, 2017 | 03:33 AM
  #232
jumph4x's Avatar
W210 DRFT BNZ
Awesome thread, just got done reading it all. <3
Old Mar 30, 2018 | 12:41 PM
  #233
dans776's Avatar
Ford Gt supercar/ 05 e55 wagon
subscribed! good info thanks everyone.
