Old Jun 17, 2015, 07:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering and Suspension Guides
Print Wikipost
My E55 DIY Coilover install With Step by step
Old Oct 5, 2013 | 03:00 AM
AutoLuxury's Avatar
2013 GLK 350 2013 GL450
Originally Posted by Manuyc
the coil overs look great
Thanks man! Credit goes to BC Racing
Old Oct 5, 2013 | 03:02 AM
AutoLuxury's Avatar
Originally Posted by viren.89
TBH , this is by far the BEST write up for DIY i've ever seen. It's so detailed and organized and full with pics.
I still won't do work like this on my own lol but man amazing job !
Please do other DIY's too, for example Brake and Rotor change in the same form since I think I'd be needing those soon lol
I plan on doing many more as I restore this car!
Old Oct 5, 2013 | 03:03 AM
AutoLuxury's Avatar
Originally Posted by OCKlasse
Looks awesome!
Clip the ends of your zip ties
I promise I did! Lol Thanks!
Old Oct 6, 2013 | 05:50 PM
uae.e55's Avatar
E55
Originally Posted by AutoLuxury
I love my flippy floppyies!
Arnotts only has the fronts when I spoke to them and they did not have them in stock I would have to send mine in and have them rebuilt. I didn't wanna deal with a compressor going out, or a pump failing, or a rear bag failing in the future. So i just decided to get coils. Besides I like to drive the twisty roads of tennessee and the air ride is a little mushy lol. I paid less then $1000 for them. They retail for $1250. I paid another $150 from Car-part.com for the rear control arms. I bought them used from a salvage yard and cleaned them up and painted them to look good!
Which one should i choose this is the arms for rear lower and upper ?
Rear Lower Control Arm
Mercedes E Class...(E320 rear RH,LH thrust arm),(Rear RH,LH,E320,spring),(E320 Rear RH,LH track arm)........
Rear Upper Control Arm
Mercedes E Class........(E320 rear ,camber strut guide, LH,RH) and ( E320 rear tension rod guide RH,LH)
Old Oct 6, 2013 | 08:00 PM
AMGPilot's Avatar
2004 E55
Front spring rate: 16Kg/mm
Rear spring rate: 15Kg/mm
900 lbs/in
850 lbs/in
for those of use that think in imperial
Old Oct 7, 2013 | 02:12 AM
AutoLuxury's Avatar
Use this:
Old Oct 7, 2013 | 02:13 AM
  #32
AutoLuxury's Avatar
Originally Posted by AMGPilot
900 lbs/in
850 lbs/in
Good idea!
Old Oct 7, 2013 | 10:52 PM
  #33
AutoLuxury's Avatar
Been super busy at work! I bought 3 new stores and now I'm swamped! I'll finish this soon!
Old Oct 8, 2013 | 03:42 PM
  #34
AutoLuxury's Avatar
INSTALL THE REARS
First and foremost! Major apologies to all my friends following this. I have been dealing with weather, work, and lack of time to complete this project as quickly as I anticipated.
However this is not going to be as precise as the previous install. Its simple really, remove everything and reinstall. LOL! I know too easy right? Wrong this was hell and took loads of time. So without further adieu here we go:
As usual break the lug nuts loose with the car on the ground. Chock the front wheels on both sides of the wheel.
My E55 DIY Coilover install With Step by step-photooct0390717am_zps1b24e573.jpg
Then get the rear end up in the air. The rear is a bit tricky so i suggest you use the factory jack on the jacking points in the rear and lift the car up.
My E55 DIY Coilover install With Step by step-photooct0390824am_zps40dbcfcf.jpg
My E55 DIY Coilover install With Step by step-photooct0320844pm_zpsf89deea5.jpg
Then slide a proper jack in from behind the car and you will see two big rubber pads on each side of the car infront of the mufflers. These are also jacking points. Place a piece of 2x4 in between the jack and the rubber pads and lift one side at at time untill the rear end is up high enough for the factory jack to fall out of the standard jacking point. Then proceed to install a jack stand in the factory jacking point. Repeat on the other side as well (DO NOT RAISE THE CAR AS HIGH AS THE JACK STAND WILL GO ON THE FIRST LIFT). Make sure you raise each side up a few inches at a time and stagger the lifting process. This will guarantee that the car will not fall off the jack stands but also will be a lot safer .
Once you have accomplished that. Remove the wheels and this is what you should be staring at:
My E55 DIY Coilover install With Step by step-photooct0311404pm_zpsae405aa0.jpg
Remove all the nuts holding the inner fender liner from the car. This should allow you to see what kind of carnage you are about to come in contact with.
My E55 DIY Coilover install With Step by step-photooct0460357pm_zps80e9f968.jpg
On the back back side of the rear spindle facing the rear of the car will be a connecting arm to the chassis. Disconnect this bolt from the spindle.
My E55 DIY Coilover install With Step by step-photooct0460515pm_zpsff6057fe.jpg
Remove the sway bar from the spindle and the camber arm
My E55 DIY Coilover install With Step by step-photooct0460511pm_zps2516eef5.jpg
Now take a zip tire and swing the sway bar mount up and hold the rear toe arm in place with the sway bar mount and a zip tie like so:
My E55 DIY Coilover install With Step by step-photooct0460525pm_zps9982edf7.jpg
Now trace the line leaving the shock to this junction box. There will be three connections in there. You will remove the middle one. To sever the connection you will see a small metal clip at the top. Simply insert a flat head screwdriver and pry upwards. The clip will slide with ease and you will remove the clip. Then unplug the middle harness clip by pulling with a light tug. Then insert the clip back and press firmly till it clicks in place.
My E55 DIY Coilover install With Step by step-photooct0460545pm_zpsf868e659.jpg
Lets get that pesky shock out! LOL! Remove the bolt from the control arm. Enter your trunk and remove the liner from the same side you are working on and undo the top nut. Compress the shock by hand it should come out easily.
I forgot to take a picture of this step.
Now lets pull that annoying rear air bladder. The rear air bladder has nothing holding it up top except a centering bulge in the chassis and a dip on the bladders top side to accommodate the bulge. So the best way to remove the air bladder is to cut the main thick rubber hose leading to it. All the air will leak out of the bladder and it will compress like an accordion.
My E55 DIY Coilover install With Step by step-photooct0460620pm_zps27268baa.jpg
Then remove the lower bolt.
My E55 DIY Coilover install With Step by step-photooct0460552pm_zps4ffe82d3.jpg
Cut the factory white air feed line:
My E55 DIY Coilover install With Step by step-photooct0462251pm_zps17ca7916.jpg
Unclip the harness:
My E55 DIY Coilover install With Step by step-photooct0462305pm_zps5165dda2.jpg
This is what should pop out.
My E55 DIY Coilover install With Step by step-photooct0462320pm_zpsc6ac02ae.jpg
Undo the two bolts holding the brake caliper on.
(sorry no picture)
Undo this control arm bolt from the spindle.
My E55 DIY Coilover install With Step by step-photooct0312239pm_zpsd92e0fe7.jpg
Then undo this control arm bolt from the chassis:
My E55 DIY Coilover install With Step by step-photooct0312228pm_zpsd82eb6e5.jpg
Remove the control arm!
Yay! Go grab a beer/cold drink/water/smoke/or pop a squat! The hard part is over with!
Now reinstallation is the reverse of removal.
1. Insert new control arm with spring cup to spindle and bolt down
2. Seat the spring as per manufacturers instructions and insert rear control arm bolt
3. Feed top of shock through trunk hole and bolt down with proper bushings. Then connect eyelet bolt to the shock and control arm.
4. Install camber arm.
5. Install brake calipers
6. Install rear toe arm.
7. Install sway bar.
8. Install rear fender liner
9. Repeat on the other side.
TADA You are done. My phone battery died so I didn't get to take any more pictures. I feel sad now. Adjust your coilovers as per manufactures instructions!
My E55 DIY Coilover install With Step by step-photooct0460402pm_zpsb2bb665a.jpg
****TO DISABLE AIRMATIC AND AVOID THE WARNINGS ON THE DASH. JUST OPEN THE DRIVER SIDE DASH FUSE BOX. AND PULL FUSE F037 AND ITS DONE. NO MORE AIRMATIC WARNINGS AND NO MORE VISIT WORKSHOP WARNINGS.****
My E55 DIY Coilover install With Step by step-photooct0823418pm_zps6796d4f6.jpg
IF YOU WANT TO GO LOW YOU CAN WITH THESE:
My E55 DIY Coilover install With Step by step-photooct0390021am_zps980a44f3.jpg
My E55 DIY Coilover install With Step by step-photooct0390033am_zps793574c6.jpg
My E55 DIY Coilover install With Step by step-photooct0390041am_zps66c9227a.jpg
My E55 DIY Coilover install With Step by step-photooct0390050am_zps8dfb5daa.jpg
The only thing i had to purchase was the control arms to install the BC Racing MBR Type Coilovers. Nothing else.
Old Oct 8, 2013 | 03:46 PM
  #35
AutoLuxury's Avatar
Would a moderator please combine my install posts with the original first post so this can be concise?
Thanks fellas. Im sure some of you will have questions as well!
As per the settings I have the front at 15 and the rear at 15 and the car sitting 1 finger above the tires. It sits level and drives great. Go get an alignment after you are done!
Old Oct 8, 2013 | 04:36 PM
  #36
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Nice
Old Oct 8, 2013 | 05:00 PM
  #37
shardul's Avatar
2003 W211 E55, 2003 W220 S600
major props for doing this in a parking lot without a lift!!!!
Old Oct 8, 2013 | 05:05 PM
  #38
berti_00's Avatar
2016 Cls63s AMG
bad a$$ job man... thats sick how you took the job in a parking lot, major props
Old Oct 8, 2013 | 05:09 PM
  #39
AutoLuxury's Avatar
Originally Posted by BI-Performance
Nice
Thanks!
I know crazy right!?!?! LOL!
Man I have never been afraid to turn wrenches. I have yanked a trans out of a car with rocks as jack stands on the side of the highway to replace a clutch. Hand tools and a set of cojones to try anything helps!
Old Oct 10, 2013 | 12:17 PM
  #40
Lawrence1's Avatar
2011 G55 + others
Thanks for posting this DIY.
Can you post a brief review of the suspension, now that its installed, and also share with us what the difference is in handling, feel and ride quality as compared to the Airmatic system you removed? This would be really helpful to those out there that are on the fence about going to a coilover system but wonder how that will change the handling and ride characteristics of the car.
Old Oct 11, 2013 | 11:32 AM
  #41
BaDiNfLuEnCe55's Avatar
2004 m3, 2005 e55
Please let us know the ride compared to the airbag.. Is it like a big change in feel
Old Oct 11, 2013 | 12:28 PM
  #42
Denroll's Avatar
'06 E55
Really good contribution to the community.
How easy/difficult is it to adjust the height once it is all installed?
Old Oct 11, 2013 | 04:23 PM
  #43
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
****ing BOSS, for doing it in the parking lot
Old Oct 12, 2013 | 09:40 AM
  #44
AutoLuxury's Avatar
To be honest in full soft the car rides like stock! The only thing you notice is the springs have more rebound to them then the airbags. ON full stiff it rides like a monster! Holy **** this thing feels like my GTR on R mode. I am going to go kill some of my favorite backroads today after an alignment. So stay tuned!
It is a big change! The car feels more responsive! there is a lot more feedback from the car to the driver. Every transition is explainable.
Easy. Just jack the car up! and adjust them as necessary.
I appreciate it man. I cannot wait for the house to be done so i can have my garage back.
Old Oct 12, 2013 | 04:27 PM
  #45
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Hope they make a kit for the SL soon.
Old Oct 12, 2013 | 08:56 PM
  #46
AutoLuxury's Avatar
They will work with you to get a set made!
Old Oct 14, 2013 | 02:29 PM
  #47
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I had a set of BR series on my E46 M3 and was pretty happy with them...
So in summary... you need rear control arms(with spring cups), and a set of coilovers. Then uninstall and reinstall as you would do normally with a control arm replacement on the rear.
Pull the fuse for airmatic(or in Star code for no Airmatic)... If I had access to a lift then it would take maybe a long day to do and delete airmatic from the car. I wonder how much weight it would save
Old Oct 14, 2013 | 05:08 PM
  #48
AutoLuxury's Avatar
It was a good 30 lbs saved after the compressor and airmatic was removed.
Old Oct 14, 2013 | 05:15 PM
  #49
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i would say you save a ton of weight as i just replace one of the front airmatics myself with arnott one and they are heavy as crap! it felt like it was holding up a 45 lb barbell plate with one hand while pushing down on the lower control arm to get the bottom of the strut in...
plus you would eliminate the compressor too which is pretty heavy too
i would think you save 20lbs on each corner plus whatever the compressor weighs
Old Oct 14, 2013 | 06:31 PM
  #50
AutoLuxury's Avatar
I never got a chance to weight the whole setup coming out of the car. But i did weight the setup of the car going in and it was significantly ligther than what i pulled out
