New: FSP Pulley Review with EC Tune 2.0 (Jerry/Brooke/Shardul)
Old Oct 20, 2013 | 07:45 PM
  #126
SilverStrk's Avatar
05 E55, 07 ML500
Originally Posted by dllhg
What happens if you install this With out a tune?
Death....... As in Boooooom..
Old Oct 20, 2013 | 07:46 PM
  #127
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
So with no added boost it can blow your motor removing the clutch ? Wow, had no idea.
Old Oct 20, 2013 | 09:30 PM
  #128
sircl55amg's Avatar
2006 cls 55 amg
the only trouble with this pulley is...the buypass valves needs to be open at idle and in deceleration
so you need a tune for it
Old Oct 20, 2013 | 10:03 PM
  #129
viren.89's Avatar
2004 E55 AMG
Oh nothing at all, given that your car stays parked at home and you don't
drive it
Old Oct 21, 2013 | 12:50 AM
  #130
dllhg's Avatar
drive it
huh ? I drive the heck out of my car every day. NM I think I get it now.
Old Oct 21, 2013 | 02:37 AM
  #131
V TO E55's Avatar
05 E55/08 C6 Z06
Do you guys still install the resistor on the s/c clutch plug even with the tune?
And just to make sure..the plug is to the passenger side under the s/c magnet right?
Old Oct 21, 2013 | 10:37 AM
  #132
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
yes the resistor is required.
Old Oct 21, 2013 | 11:11 AM
  #133
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Pulley
Anyone have a dyno sheet on a modded engine headers,pulley,throttle body ,cams.?
Old Oct 22, 2013 | 10:25 AM
  #134
uberwag's Avatar
2017 SQ5 / 2012 Ferrari FF
I'll have one soon for a 77mm supercharger pulley with a stage 3 (injectors, looped rail, 82mm TB, headers (de-cat), and heavy cooling mods), but no ported heads/cams. Jerry and John are working on it today in Houston, and I'll be glad to share when it's done.
Old Oct 22, 2013 | 12:54 PM
  #135
dllhg's Avatar
Couldnt any decent tuner modify your tune for this ? I cant imagine too many people with custom dyno tunes are going to want a canned tune or start from scratch just so they can get this mod. I personally would be ordering it right now if I knew I could easily get my tune modified to make it work.
Old Oct 22, 2013 | 01:01 PM
  #136
Bramage's Avatar
F-250
Call your tuner... I am sure they can speak to it.
Old Oct 22, 2013 | 01:07 PM
  #137
Bramage's Avatar
F-250
The 77 / 180 combo will put you in the 18.x PSI range. I cannot get anythingover 17.5 to work. I know I could defeat the MAP via a map-clamp or somethingcomparable, but I don't have the stomach for it.
I will be watching your progress.
Old Oct 22, 2013 | 01:49 PM
  #138
uberwag's Avatar
HAHA should have clarified..it is a 77mm supercharger pulley and replacing the 180mm crank pulley. Good catch, should have pointed that out.
Old Oct 22, 2013 | 01:54 PM
  #139
dllhg's Avatar
I guess I would need to go with stock size with my 185 lower or could I get away with the 83 maybe ? What is a stock sized pulley anyway ?
Old Oct 22, 2013 | 02:09 PM
  #140
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
90mm
Old Oct 22, 2013 | 02:14 PM
  #141
dllhg's Avatar
Damn even the 83 is a big difference then. On my GTO dropping every tenth of an inch increase boost a good amount. Wish they had more choices on sizes. Also be nice if they listed the amount of boost increase for each size.
Old Oct 22, 2013 | 02:39 PM
  #142
This is relative to your mods of course.
https://mbworld.org/forums/w211-amg/516924-pulley-size-boost-calculator.html
Old Oct 22, 2013 | 04:29 PM
  #143
Bramage's Avatar
F-250
I have 190mm with an 83mm and its overboosting (17.8 PSI). I have an 89mm top pulley on its way
from Houston.
Looks like it would put you just over 17 psi.. TRY IT!!! Its on the edge, but under the 17.5 threashold!
Old Oct 22, 2013 | 09:28 PM
  #144
dllhg's Avatar
Wow, so going to a 83 adds two pounds of boost ? According to that chart it makes a good bit more boost than a 195mm .......... They need to get some more in between sizes on those upper pulleys.
from Houston.
Old Oct 23, 2013 | 10:16 AM
  #145
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
sigh, I liked having money in my pocket... I think I'm sold on the the plan... 80mm FSP, PLM heat exchanger, secondary cat and res delete with x pipe. And then possibly split cooling and some type of way to monitor IATs. I think this will give me a good balance of beauty and beast
Old Oct 23, 2013 | 10:31 AM
  #146
ArmoE55's Avatar
2006 E55
The smaller upper pulley is actually 84mm, not 83.
I am not talking to the accuracy of that chart posted, but I gained about a pound of boost over stock. My lower is stock.
I logged using TORQUE and my boost went from ~10.4-10.5 peak to about ~11.5 peak.
Old Oct 23, 2013 | 11:52 AM
  #147
dllhg's Avatar
Monitoring your IATs is super cheap and easy. If you have a Droid it will set you back about $20 total. I use a blue tooth OBD2 and Torque ($5). Works very well.
hmm..... I was wondering about this. Those numbers did seem very high to me. So you went with the 84mm and gained 1 lb ? On my GTO every tenth adds close to a lb. The 84 would be just about a 1/4 inch. Of course the starting size of the W211 pulley is larger at 3.5 inches VS the 3 inches on my other blower. I would have expected a good 1.5 LB PSI dropping that much. You really need to test with the same conditions too. Cooler temps raise boost.
Old Oct 23, 2013 | 12:22 PM
  #148
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
Just to add to this thread...I have seen and met a few guys running this pulley and their cars are running strong. I can't believe what a SC pulley is doing to the AMG's compared to what it did 6 months ago which was barely any gains (20-30whp). Now it is very impressive as I have seen them run! The negative is...every guy that I know with the pulley and the EC tune is having shifting issues. They are not major issues but seems to be a small glitch somewhere. Can't these guys solve the problem and is anyone else on here having the same problem? I only want to see their cars at full potential.
I don't know exactly what the shifting issues are but I am sure that someone will explain and maybe it is posted earlier in this thread but I didn't have the time to read through this entire thread.
I have heard many good things about EC so please do not take this wrong. I am just curious what the issue is and to try and help my friends get it straightened out.
Old Oct 23, 2013 | 12:29 PM
  #149
ArmoE55's Avatar
2006 E55
Ambient and IATs were roughly the same, give or take a few degrees hotter actually when I tested the smaller pulley addition and dyno tune. I tested literally two days apart to see the log difference in boost, timing etc. The delta was .9-1.1 increase in boost with the addition of the upper pulley. I am very happy with the results..the car is MUCH more crisp and engagement far less abrupt and more subtle now. The power comes on substantially harder and quicker, but smoother...if that makes any sense.
And to be honest, I would not feel comfortable without a clutched pulley, but that's just me. I like the comfort of engaging and disengaging as I please with my right foot. My .02 on the whole FSP product.
Old Oct 23, 2013 | 01:49 PM
  #150
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Just want to understand this better, is this correct ?
90mm ==> Stock
84mm ==> smaller pulley with clutch
80mm ==> Fixed pulley without clutch
77mm ==> who makes ?
