ipod connection
Old Oct 20, 2013 | 08:48 AM
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
ipod connection
Looking for some help here. My 08 e63 has the ipod hook up. When I want to use I have to hit AUX on the COMAND unit. So it doesn't show me the name of the song or albums, nothing. But in the info cluster by the steering wheel I can see the name of the song. What gives?
Also, for some reason it won't Charge my ipod while it's plugged in??
You help is appreciated
Old Oct 20, 2013 | 09:56 AM
ahmad0658's Avatar
Brabus K8 E55 05
This is what I also have. You can change through tracks, songs, etc.. using the the arrows or the square ( I don't remember) but you can do it.
Recently, I don't have sound coming out of the ipod or iphone when plugged into the cable. Maybe I have a cable lose from the command system.
If anyone can help with instruct me to what to check I would appreciate it so much ..
Old Oct 20, 2013 | 02:24 PM
GunMoto's Avatar
EG8 | E46 | W211
IIRC, NTG2.5 did not start until 2009 W211s, so I presume you still have the NTG1 COMAND. For NTG1, the AUX input is simply that, just an input for an audio source (i.e., 3.5mm stereo jack). When you add the iPod integration kit, the module separates the audio from your dock connector to the AUX input of the COMAND and the iPod signal controls to communicate through the IC. Unfortunately, I'm fairly certain there is no way we can get the artist/song title info to display on the COMAND using AUX.
For charging, you need to get a charging adapter to convert the 12v lead to 5v (I used the Scosche passPORT to charge my iPhone4). Since then, I added a bluetooth receiver to the iPod integration cable so I can connect my iPhone wirelessly.
Old Oct 20, 2013 | 04:30 PM
p30amg08's Avatar
Thanks for the detailed response sir. your are right that 2009 started the different comand unit.
Here is another question, if I find a 2009 e350 - 550 that's being parted out, can I replace my comand unit with it without and modification will it slip right in?
What are the pro and cons of that? Typically what wud u say they are worth and what is the COMAND unit I have worth. the navigation dvd was updated to 2013 if that means anything ?
Just pondering since I really want to see the title, albums, etc on the screen and I really want to get a backup camera since I'm used to having that in all my cars. I was told by my local best buy backup cam isn't a possibility with my unit...
Btw how is sound quality over bluetooth?
Old Oct 21, 2013 | 08:14 AM
p30amg08's Avatar
Anyone?
Will a 2009 e class comand unit slip right into the 2008? Any issues with connections?
Thanks!
Old Nov 29, 2013 | 11:10 PM
e63amgrami's Avatar
E63 AMG
I have an E63 amg 2007. I have a Bluetooth receiver but for some reason it doesn't pick up music just phone calls. If you can please send me a link of the one you purchased I would really appreciate it. Thank you.
Old Nov 29, 2013 | 11:34 PM
GunMoto's Avatar
EG8 | E46 | W211
The bluetooth receiver needs to support Airplay and A2DP music streaming protocol.
Do you have an iPhone? Is your bluetooth receiver connected to an iPod integration kit? Or, 3.5mm audio jack?
This is the one I use:
http://www.viseeo.com/ugC_ShowroomIt...p?hidShowID=15
Search on eBay for a new unit.
Old Nov 29, 2013 | 11:56 PM
e63amgrami's Avatar
E63 AMG
I have an iPhone 5. I am just trying to hook it up through Bluetooth wirelessly. I would need a different Bluetooth hook up.
Old Nov 30, 2013 | 10:58 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Awesome … this works for NTG 2 also? I have been looking for something like this .. how's the sound quality through BT?
Old Dec 2, 2013 | 09:03 PM
turbo97se's Avatar
Just wanted to post up. I just got mine today and it works great! Sound quality via BT was surprisingly decent! Thanks for the recommendation GunMoto! .. works with iPhone 5
Old Dec 2, 2013 | 10:21 PM
GunMoto's Avatar
EG8 | E46 | W211
Awesome!
Also remember, if you're streaming music (which I do), then SQ won't be the best. Also be aware of what bitrate your mp3s are encoded in if you store them on your iPhone.
It's so convenient not having to plug-in your iPhone to listen to music. Now, you only need a plug for charging.
Old Jan 28, 2014 | 10:21 PM
Slotboy's Avatar
2008 C300
iPod connector loose
(Edit) Sorry, wrong thread
