Rain sensing wipers gone beserk
Old Nov 1, 2013 | 07:19 AM
viren.89's Avatar
2004 E55 AMG
So apparently they are sensing rain for no reason and running.
When it's actually raining, they just run at second speed. Seems to me like when it's dark outside, they think it's raining.
Are there some sort of sensors that need replacing after a while? As like a maintenance item?
My wipers are kinda worn out but I don't think that could be causing that?
Sometimes even on a sunny day they'll run and I'd have to turn the wipers off and then turn it back on and then they will stop.
Suggestions? Recommendations?
Old Nov 1, 2013 | 09:51 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
there is a control module for the wiper on the front cowl that may be going bad. I have a couple of used ones if you are interested.
Old Nov 2, 2013 | 05:50 PM
pnoyworx's Avatar
10 E63, Sold -07 E63
Try cleaning the sensor area on the windshield. Scrape it with a razor, maybe tree sap, or something simulating rain.
Old Nov 3, 2013 | 07:31 AM
mtrevelino's Avatar
2006 E320 CDI
The switch is not supposed to be left in the auto position. This is stupid but this is what the owners manual states.
Mike T.
Old Nov 3, 2013 | 11:54 AM
viren.89's Avatar
2004 E55 AMG
I took the module out, it is behind the rear view mirror. No broken wires or no nothing.
I took the car to my mechanic , after 5 mins of looking for the "service port" which he said this car doesn't have we tried the OBD plug in and using that DAS wasn't able to
communicate with anything , let alone this module. They need the service port to correctly diagnose the problem.
Does anyone know where that is ?
Shardul you certain that it is under wiper cowl ? or there is another one underneath there?
Old Nov 3, 2013 | 01:55 PM
shardul's Avatar
Ok I think your tech needs some more training in newer cars. There is no service port on post obd1 cars the obd2 port serves as a data connector to the car.
Check the part that I told you about
Old Nov 3, 2013 | 01:57 PM
viren.89's Avatar
2004 E55 AMG
Can you tell me where exactly is it located?
Exterior of the car, next to the wipers? Or somewhere else?
Old Nov 3, 2013 | 06:54 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Agree ... you need to find a new tech or a tech familiar with newer cars. OBD port on almost every car I have seen is under steering column. He should be diagnosing with star before removing anything in any case.
Old Nov 5, 2013 | 11:46 AM
viren.89's Avatar
2004 E55 AMG
Every time it's connected through the port, the machine gets a message that it cannot generate service features.
It does everything else , just not service related features.
Old Nov 5, 2013 | 06:39 PM
turbo97se's Avatar
Is the scanner from this millennium?
Old Nov 7, 2013 | 03:41 PM
viren.89's Avatar
2004 E55 AMG
It's called MAXIDAS and I did get it scanned for all the modules and everything and still shows that everything works.
