Anyone running 235/35/20 F?
Old Nov 21, 2013 | 02:57 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
My guy at the tire store says he has had excellent luck with them. It is the tiniest bit of spec off a 245/40/20. My car is pretty low in the front, and I wouldn't mind that extra MM or two of impact protection, and maybe just a touch lihgter steering effort. He has both in stock so I'm going to fit them up and see. Just wondered if any of you guys had tried it, maybe you had a picture also....thanks.
Old Nov 21, 2013 | 04:35 PM
£ C43 £ AMG £'s Avatar
E55K AMG
A new 245/40/20 will rub on the upper arm ball joint thread... I ground about 5mm on mine and it was fine
Old Nov 21, 2013 | 09:15 PM
E55Dimon's Avatar
E63S
Its gonna sit pretty high..
Old Nov 22, 2013 | 12:16 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Your front tires will be over ¾" taller than stock and you will have decreased your contact patch in the front.
Old Nov 22, 2013 | 09:06 AM
allenjdmb's Avatar
Mmmm,
no, I'm running 245/40 now with no interference or trimming. And the overall difference will be less than .75, not more. At least in the PSS.
We'll see when I get there.
Old Nov 22, 2013 | 09:48 AM
HeissRod's Avatar
Wait, you're running a 245/40_20 right now? That's 2" taller than stock! That's not a tiny bit off spec. The correct upsize tire for moving from the stock 18" rim to a 20" rim is 245/30, not 245/40.
As far as overall difference between the stock 245/40_18 and the 235/35_20, it is 0.76".
Old Nov 22, 2013 | 10:52 AM
allenjdmb's Avatar
Doh!
I'm a dumbaxx....yes Im running 245/30....
Old Nov 22, 2013 | 11:04 AM
ALEN35's Avatar
2007 sl65 amg
i am running 245/35/20 in the front and 275/30/20 in the back on stock susp.
No rubbing!
Old Nov 22, 2013 | 06:26 PM
E55K AMG
100% 245/40/20 rubbed on the upper arm ball joint bolt when I used the brake and went over bumps,
I now have 255 30 20 and they are fine, I switched to this size after I buckled 3 front wheels as 245/30/20 looks great but it has little protection
Old Nov 22, 2013 | 07:59 PM
allenjdmb's Avatar
Unfortunately,
that wont work for those of us with low ride height...that's why I was wondering about the 235/35....
Old Nov 24, 2013 | 08:00 PM
E55K AMG
I have an ELM + lowered in STAR DAS ........dropped approx 100mm with KMAC
