Battery protection convenience function temp unavailable
If the warning that comes on says, "Low Battery Convenience Functions Temporarily Unavailable", that typically means your main battery is weak and/or needs charge by your alternator. Typically, this occurs when the weather gets colder (I am no mechanic, don't know why that's the case).
On my previous 06, I had this warning come up during winter months, especially if the car say for more than a day without driving; it was never an issue during the summer/warmer months. I replaced my main battery with a lighter one. Luckily, I haven't had this issue on my current 06.
I would be concerned if it comes and goes while driving. If the battery is a bit low from the car sitting all week, I would expect it to come on soon after start, and the go away and stay off.
So, was that alternator new, used, or rebuilt? How old is the main battery in the trunk?
I created a video for removing the voltage regulator on W219 chassis, it should be applicable to W211 as well
The OP has proven this is not about replacing a working alternator or good front+rear batteries.
Something else is causing low chassis voltage...
Do we know what W211 low voltage measures?
The BCM may be guilty... I dont know how to test it?
