Considering making the jump.
Always been a BMW guy my whole life and I'm in the market for fun yet nice daily driver while the M5 sleeps in the winter. I came across an absolute gem of a W211 AMG locally from sale by a gentleman who has babied this thing. He has a stack of service records from the dealer to prove it.
Now, being an OCD maintenance guy and coming from the world of M cars, I am no stranger to high upkeep costs on German performance cars; although an automatic + luxury infused + supercharged 10yr old car is sure to give me a wake up call, lol.
I am wondering, apart from the air strut failures around 120k miles, what other things are known to need some TLC around this mileage? Are the S/C bearings a commonly known failure item?
In my search of a daily driver, a MB let alone an AMG never crossed my mind. But once I saw this one was within my budget, I haven't stopped thinking about it. It truly would be one helluva car to own in tandem with my M5, the W211 has been a car I lusted after ever since Road & Track reviewed one back in the early 2000s!
Fuel pump
Change all fluids
@ 120k there will be certain suspension components that will need to be replaced.
If you plan to use it as a daily driver LEAVE THE CAR STOCK
Booooo!!!
To the OP: probably swap out the IC pump too if you don't see that it's already been done recently (use the Bosch "010" version)
I will warn you know now that a good running E55 is likely to make the M5 feel like a waste of your garage space.
the ludicrous torque of the E55 is addictive.-G
My only gripe is that it doesn't have an AUX or iPod hook up
What's the cheapest way to get my own music into this brute? The car has Harman Kardon audio, bluetooth, but no Nav.We agreed on a price. The transaction should be closed tomorrow evening or by Friday at the latest. Needless to say, I am pretty excited about this car
Mods are my sickness. I have spent more on mods on some of my past BMWs than those cars were actually worth. Seriously. Tens upon tens of thousands. I swear, a fatal cocaine addiction would've been cheaper.
SA 044 NEW TELEMATICS GENERATION NTG 2.5
SA 521 RADIO AUDIO 50 USA (WITHOUT NAVIGATION)
My headunit has built in bluetooth and a in dash CD changer. No Aux option anywhere in the Menus or in the glovebox. I take it the Aux harness should be a straightforward install with this Audio 50 unit?
That said, I've already had one front air strut fail (1st time stranded - replaced both fronts with fresh Arnott units), inner front tie rods are done and (I ride with the car lowered about 50% of the time, but at a 25-35mm drop, if you ride low, the tires need replacing every 30K mi), engine mounts are done, main battery replaced due to voltage issues with interior electronics, driver side xenon ballast failed, dual pulley failure/accessory belt shredded shortly after some mildly spirited driving (2nd time stranded), and the sunroof drain holes leak if the car is left outside in the rain for extended periods of time. I'm sure there are repairs I've forgotten, but that what I can remember. Parts and labor at the dealers are out-of-sight ridiculous so I would hope you have a knowledgeable connection at your local dealer.
Awesome car though, it get looks most everywhere I go and it can hold its own with most anything I encounter on the road. Very sexy with the E63 facelift.
Nice and stock
As far as installing the cable. It is a pretty simple task. You will have to remove the head unit to connect it. Then you can remove the glove box if you want to mount it in the stock location. I am contemplating moving mine to the center console though.
However, I didn't see any wheel being lower than another or stuff blatantly indicative of airmatic strut failure. Moreover, once the car has warmed up, this error doesn't come back on start up. Ie. morning start = error. Drive for 5-10 minutes to warm up. Restart car = no error.
Thoughts? Is that the air compressor having an issue?
Issue #2:
Noticed that once in a blue moon, there's slight hesitation through 3.5-5K RPM or so when flooring on the highway during 4th/5th, pulls hard and smooth below and above that RPM. However, in 1s/2nd it plows straight to redline like a freight train. No SES/Check Engine light.
Nice and stock
Thankfully, I have a solid connection for any European car repair. Else there's no way I could afofrd to maintain these sorts of cars to the high standards I am obsessed with. I agree on the looks. It's just so "boss/prestige status," even though I paid far, far less than a new Civic for it. Lol.
Wish I could rationalize modding this one. I already have crazy ideas but it makes zero sense financially on such a high mileage E55. Pretty much gonna drive it gently and maintain until I sell it eventually... I'm sure I can see myself in a lower mileage example down the road again.
