help, think my motor just blew or head gaskets let go
I was driving across state, all of a sudden I lost heat (its 0 out here in NH), and 10 seconds later the car started to studded and then bam, a cloud of white smoke out the back)
Had the car towed to a local shop who took a quick look (I had to keep moving so I rented a car and have not had a chance to get back to it) and said there is Antifreeze in the oil.......
I thought there was some chatter on the threads about bad head gaskets, so can any of you shed some light on both the issue of bad head gaskets (car is an 07 E63) and if I have to pull the heads what else I should be doing both for protection (I think I remember something about some years having bad head studs so I should upgrade to ARP) and is there any performance work I should do at the same time....
Overall, a bit discouraged as the car continues to be possessed by issues, but I'm hopeful we can get them behind us
Any idea's of Indy shops in the NH area that has the tools to do the job and can do it proficiently?
While the heads are off, any thoughts on what else I should be doing?
These cars (motor 63) seem to be a hit/misss.
My car 74k na da...I knwo some with 130 and nothing.. some with 25k 35k PoS....
I feel for you....being such a new owner...
http://precisionimports.com
do you have any engine mods or tune? has it ever overheated on you before?
Definitely check out the m156 head bolt thread. I have several posts there documenting my story.
Replace bolts with ARP or at the very least the redesigned bolts. New tippets. Change the plugs while you are at it.
Hope it goes well.
No question, if the motor is salvagable, I'll get ARP head bolt and intake bolts. Not to mention check out the lifters.
Anyone have thoughts as to different head gaskets? The Stock one ok or is there a better one out there?
Also, being I don't have the time right now, nor the tools, what kind of money are people paying for the job at an indy shop (assuming its just R&R for the headbolts and gasket)?
statepk, being there is coolant in the pan and it was blowing smoke out of the exhaust clearly indicates there is and was a significant intrusion into the cylinders...
Do you or anyone on the board have experience on mods for the 63?
