Kleemann Header install pics?
Old Feb 14, 2014 | 02:05 AM
Toadster's Avatar
2005 E55 AMG
looking to install my Kleemann Headers (finally!)
anyone have pics of a good install? searching for "Kleemann Headers" results in a bunch of signature hits and I can't find any good links from just a 'title' search..
Old Feb 14, 2014 | 01:44 PM
berti_00's Avatar
2016 Cls63s AMG
I saw a thread somewhere diy
Old Feb 14, 2014 | 02:38 PM
MAN55LE's Avatar
04 E55 AMG
It's ok.... it's in the sticky DIY for headers doesn't have to be Kleemann, putting in headers is headers ....use 17 mm wrench to pull the plugs... try not to break any studs and if some the studs come out with nuts one...you can just reuse. Gunna have to weld....gunna take twice as long as you think. Use new gaskets and nuts that comes with it.
Old Feb 14, 2014 | 05:46 PM
E55Greasemonkey's Avatar
This place is a joke.
"search this forum"
"advanced search"
Type "kleemann headers
Check the box for "titles only"
Old Feb 14, 2014 | 07:29 PM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
I see busted and bloody knuckles in your future, young Jedi. Oh the fun I had installing those......
Old Feb 14, 2014 | 09:51 PM
Toadster's Avatar
2005 E55 AMG
Originally Posted by MAN55LE
It's ok.... it's in the sticky DIY for headers doesn't have to be Kleemann, putting in headers is headers ....use 17 inch wrench to pull the plugs... try not to break any studs and if some the studs come out with nuts one...you can just reuse. Gunna have to weld....gunna take twice as long as you think. Use new gaskets.
LOL ok, i guess I need to order some gaskets duh!
LOL - not my knuckles
Originally Posted by E55Greasemonkey
"search this forum"
"advanced search"
exactly what I did, came up with some old stuff from 2005
Old Feb 15, 2014 | 12:44 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
If Toad can't find it then there is no where to find.
Old Feb 15, 2014 | 01:25 AM
berti_00's Avatar
2016 Cls63s AMG
thats what i thought too
might not be a diy but shows something
https://mbworld.org/forums/e-class-w...lots-pics.html
Old Feb 15, 2014 | 03:17 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
I didn't think that Kleemann's could be DIYed ... thought they were weld in. But like someone said, installing headers is installing headers. Headers on this car are the easiest I have installed on any car. The copper nuts are so easy to remove and replace. 10mm gear wrench is very helpful for install. I replaced all the nuts, studs and gaskets. It's not difficult, just time consuming. Tall jack stands are a help, lift would have been nice. have fun!
Old Feb 15, 2014 | 07:59 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Couple of weekends ago it took us 1.5 hrs to install these . Yes we had a lift and and 2 people were working on the car at any given time
Old Feb 15, 2014 | 10:48 AM
turbo97se's Avatar
Damn! I'm super slow then ... Took me 6 hours on my own with Jackstands ... Took my time so no busted knuckles I also hung new exhaust. Might as well do exhaust while you're there
Old Feb 15, 2014 | 03:35 PM
lm7's Avatar
lm7
2003 E55
Todd of course you would wait for Dave to move to finally decide to install these lol!
Old Feb 15, 2014 | 04:32 PM
Toadster's Avatar
2005 E55 AMG
no joke!
Old Feb 15, 2014 | 04:34 PM
Toadster's Avatar
2005 E55 AMG
those are great! just wish they were running into the 2ndary cats (what I plan on doing)
I'm a fan of power, but I also want to be SMOG conscious too
Old Feb 15, 2014 | 07:43 PM
turbo97se's Avatar
Emissions is a joke in California. They failed my Sequoia with Fed spec catalytic converter because it did not have Cali spec converter - visual only. Replaced it with Cali spec converter and the results were worse than with my old Fed spec converter. ... still passed though.
Old Feb 15, 2014 | 10:52 PM
Toadster's Avatar
2005 E55 AMG
yes, I understand.... my 11 year old pennsylvania car burned cleaner than the new CA car we had purchased
but I'm not big on the smell of raw gas anyways - at least not for a daily driver
today I took our Miata over to get smogged, and it was the 'new' system - took about 10 minutes, ECU passed, quick visual - and DONE!
Old Feb 15, 2014 | 10:53 PM
Toadster's Avatar
2005 E55 AMG
pics? or tips? where's the best weld spot?
Old Feb 15, 2014 | 11:05 PM
Toadster's Avatar
2005 E55 AMG
which exhaust gaskets are best to use? seeing a couple kinds..
1 set seems to be individual gaskets per cylinder (8 needed)
Size:  1.7 KB Name:  zpznr8js.jpg
and the other style looks to be a left/right side (2 long pieces)
what's everyone prefer?
Old Feb 15, 2014 | 11:10 PM
MAN55LE's Avatar
04 E55 AMG
If you got it from Kleeman they come with in the packaging. gaskets, new brass nuts, referring to your two pictures the upper picture......thats you need if you were going to buy them individually, but they should come right in the packaging from Kleemann
Old Feb 15, 2014 | 11:33 PM
berti_00's Avatar
2016 Cls63s AMG
+1
why you looking for gaskets. they came with gaskets nuts and all
Old Feb 15, 2014 | 11:43 PM
10mm gear wrench is your friend for this job. You'll also have to disconnect the steering shaft at the rack (just the one end-13mm). The gaskets and nuts included with the headers are O.E.M... As O.C.D. as I can be, I ordered the factory nuts and gaskets, and couldn't believe they were exactly the same as the ones from Kleemann. Youll have to cut the pipes right behind the primary cats and take the car to a muffler shop. I can't tell you where to cut them because I cut mine too short...ughh..I would say cut them at the weld on the cat...the muffler shop can always shorten them.
Old Feb 15, 2014 | 11:58 PM
turbo97se's Avatar
I used these. Never seen the others before
Old Feb 16, 2014 | 12:02 AM
turbo97se's Avatar
Oh yeah .. if you have to disconnect steering rack set it back (towards the driver) before disconnecting. It took me a while to figure it out. Mine was forward and it causes the slider to not clear.
Old Feb 16, 2014 | 01:57 AM
cm60k's Avatar
Is that picture of 1 piece long gasket for M119 Engine...!, i think Kleemann not provides 1 piece gasket, isn't...?
usually, M113 comes with separate gasket pieces....!!
ZAYED,,
Old Feb 16, 2014 | 10:55 AM
You also need at least 2 6mm nuts. Some of the studs will unscrew from the heads with the 6mm nuts still attached. You need to double nut these studs then remove the 10mm nut. Then screw them back into the head and tighten. Then remove the 2 6mm nuts. Dpuble
