SUNVISORS
Old May 29, 2014 | 05:50 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
SUNVISORS
Anybody out there running a sunvisor other then AMG (alcantara)? Both mine are toast and OE discount parts wants $498.75 per visor. Anybody running a stock E500 visor? if so, how does it look and where did you buy? Thanks
Old May 29, 2014 | 06:08 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Check the classifieds to see if anyone is parting a car out.
Old May 29, 2014 | 06:24 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Always do Hrod!
Old May 29, 2014 | 06:50 PM
justinwrock's Avatar
Ducati
Is the mechanism sticking or is the seam separating?
I was able to resuscitate mine that were stuck by lubricating the arm.
Old May 29, 2014 | 07:01 PM
Mi2wilson's Avatar
2004 E55
There is a few e55 part outs from shardul. H&R might have. It's in the part out section
Old May 29, 2014 | 09:20 PM
E55Greasemonkey's Avatar
This place is a joke.
I fixed mine. Split them apart, greased the shaft and reglued with white Gorilla glue (only use a little!!) and hold together with masking tape to dry.
Old May 29, 2014 | 09:31 PM
HeissRod's Avatar
Originally Posted by DGSU4EA70
Always do Hrod!
Well, damn. That sucks that you haven't found one. I'll need a driver-side one eventually.
Old May 30, 2014 | 07:16 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Mine has a broken mirror...
Every time my wife touches it the mirror falls out. Gray Alcantara if someone has one....
Old May 30, 2014 | 11:24 AM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Both! My drivers side is frozen (cant flip up and down without some strength), and it separated just a week ago when we had the heat wave here. Its Effd as I took a closer look yesterday. Some of the plastic broke and I imagine i will find it when I vacuum next. The passenger side is repairable it just came unglued!
Old May 30, 2014 | 11:25 AM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Grease! Gorilla glue a product to buy online or Home Depot or Autozone? TY
Old May 30, 2014 | 01:14 PM
TheOtherDodge's Avatar
2005 E55 AMG
My driver's side was sticking and really hard to move. I took it off, held it rod side up and dripped some WD-40 down the shaft and slowly rotated it. Now it is as good as new!
Old May 30, 2014 | 01:38 PM
Ducati
This.
Just don't force it, otherwise the internal mechanisms break, and it won't fully sit against the roof.
Old May 30, 2014 | 02:01 PM
Quicksilv3r's Avatar
2008 BMW M3 Sedan 6MT - Silverstone II/Fox Red Extended
I've been hunting a driver side sunvisor for almost a year now with no luck. It's typically one of the first items to go on a parts car or it's mangled beyond repair. Ebay tends to only have the secondary visors available which I don't need. I tried the lubrication methods described above since my original one was sticking horribly and rufused to sit flush against the headliner. Nothing worked so I trashed it, not knowing it was a $500 part from the dealer at the time.
Old May 30, 2014 | 03:59 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Quick - I have been hunting the elusive drivers side as well for awhile now. Seems when I see one its already spoken for! You can always try junk yards or buy a stock E500 one, it wont be alcantara but they dont look that bad. Yeah $500 is ridiculous especially when there just glued instead of being stitched/glued. My dealership wanted $700 plus!
GL in your search brotha!
