Eurocharged s/c pulley defected
05 e55 amg
Hello im just woundering my sc pulley is making a noise sounds like a bearing .but theres no signs that the bearing is bad ..I found that the back plate of sc pulley is lose and the springs may be bad ..can you guys help me define this if its true or no ? I will contact Eurocharged soon
pretty hard to tell as the engine is running, but the clack its making sounds like the plate is loose.You can be sure by taking the belt off and spinning and feeling it with your hand. Try if the plate is loose or not, it should be "solid" a little bending movement only when you push it towards the magnetic clutch.
Received 1,488 Likes
This place is a joke.
Before you all jump on the bashing bandwagon, look at his other post with the 2mm+ gap.
https://mbworld.org/forums/w211-amg/...ap-pulley.html
Who knows if it's even pushed on all the way. MY SC pulley is over 1 year old with thousands of miles...no problem....likely because it was installed PROPERLY.
05 e55 amg
Hey thanks to all for the reply ..I did take the shims off but the engagement plate is still lose ..I guess im goingt to talk to jerry or philip ..thanks again ..
05 e55 amg
http://m.youtube.com/watch?v=3lYzWrdNzoY
Heres whith no shim on it ..it closed the gap a lil bit but still engagement plate lose .I have nothing against eurocharged and no im not posting this to talk sh$@ about them im just doing it just to share my issue ..I love eurocharged customer service. .so dont get me wrong guys
i think its just good to report the issues with this pulley...the fabricator will make ajustement to resolve all problem ... its still recent mod that needs more testing
when the bearing goes, the pulley can tweak a bit and not be linear in rotation - my guess it that you need a new bearing, pretty cheap solution...
if one of the springs is broken, talk to the vendor
If the pulley is new then the bearing shouldn't go bad either.
From multiple threads I've seen the general consensus was that the gap need to be anywhere
between .35-.45 mm.
Over and under could cause problems.
After multiple failures the second gen S/C pulley has different springs and all.
That's what I've read.
between .35-.45 mm.
05 e55 amg
When a bearing is bad does the lil rubber thing that holds it has to come off ? It happend to me befor and on this one its still intact but ill replace it just in case
