Aluminum rotor hats for the right person.
They can take about 50 lbs off in un sprung weight, with the right rotors. The silver front hats are off a SL55 but as I recall, they use the same offset as the E55 fronts and the backs are custom made but did not quit fit on my CLm, so they are also extra..
On my CL, I used custom fronts and SL55 rear hats with disscontinued evosport rotors.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Evosport was cutoff well before they went under and we now sell the rotors under our own name. The rotor rings can be purchased and fastened to the old Evosport hats shown in this thread. ACG is our only stocking distributor in the US for Mercedes rotors and would be happy to help you guys out with rotors, great group of guys over there.
No worries! There's so much misinformation out there, I mean it is the internet after all! We just do our best to keep it to a minimum.
Girodisc originally did the Evosport units.Evosport was cutoff well before they went under and we now sell the rotors under our own name. The rotor rings can be purchased and fastened to the old Evosport hats shown in this thread. ACG is our only stocking distributor in the US for Mercedes rotors and would be happy to help you guys out with rotors, great group of guys over there.
