TEXAS MILE OCTOBER 2014 RESULTS
Old Oct 27, 2014 | 01:47 PM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
Well, this is the best I could do with the problems I was having. These times are with 9 mph head winds and 88 degree temps. Oh, and my heads were lifting. My first 180 mph caused my car to overheat a little. My second was more noticable. Both runs felt like my car was loosing power at the end.............and they were. In fact, my heads were lifting while I was on the dyno at Dallas Performance a few months ago. Coolant was being pressurized out from the reservoir after each run. We assumed the 100 degree temps and lack of air was the culprit. Hindsight is always 20/20. I parked the car, but for a few full test runs, until the October race. I have burned through 1 & 1/2 quarts of oil for @150 miles. Assuming, of course, my engine is still breaking in since it has only 1300 miles on it since the rebuild and all runs were ***** to the wall.
Although this is upsetting, it kinda is exciting. If I put the power down and ran these mph's with lifting heads.........what can I do when it is solid? Factory head bolts will be replaced with ARP bolts and I will have the heads ported more (if Shardul sees room for improvement)
Light at the end of the tunnel? I believe so.......
Old Oct 27, 2014 | 02:19 PM
SPatykAMG's Avatar
W211 E55
Very solid speed for a car of this weight and having pretty serious power loss
Old Oct 27, 2014 | 03:05 PM
blackbenzz's Avatar
haters crazy
Congrats on your runs on less than ideal conditions
Your engine should not be burning that much oil. Rings should have seated a long time ago (1300 miles is actually alot for break in). Definitely throw ARP head studs in there. Would've thought you definitely had that with a built motor. Don't worry about porting heads more. Hopefully everything looks ok when you get those heads off Get them checked to make sure nothing was warped when overheating/lifting the heads. Let me know if you need anything and I'd be glad to help. These cars can be a headache (first hand experience) but don't give up. You will get to where you want to be. If you were local I'd say bring it by this weekend and I would throw in studs for you
Old Oct 27, 2014 | 04:32 PM
EREBUS's Avatar
You are a good man. Thank you for your offer.........and the advice too!
Old Oct 27, 2014 | 04:34 PM
EREBUS's Avatar
Damn it man, you live in Houston........you should of been running your car there!
Old Oct 27, 2014 | 06:32 PM
RaceHorse's Avatar
CL65
Hey congrats on the 180 mph, it must have felt pretty good. Hopefully everything gets sorted out quickly to get you back up and running strong. I looked at a few events in the north east and they seem to be really strict with safety....You need a cage over 135 mph. I'll have to check out the registration requirements, but at the same time Texas is not right around the corner from NY. A 1 mile event is on my things to do list one of these years. How about some video?
Old Oct 27, 2014 | 07:06 PM
chawkins2001's Avatar
2006 E55 AMG
congrats brotha, that's doing some work. so happy for you!!
Old Oct 28, 2014 | 08:45 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
Congrats on hitting 180 and good luck sorting out the issues. Hopefully I'll make it there next year.
Old Oct 29, 2014 | 07:07 PM
Thericker's Avatar
V12-Biturbo
Congratz!
I was obviously wrong on your CAI setup, 180 mph on 55k is legit! Obviously your Meth setup canceled out ALL of these hot underhood temps since you note ambient being 88 degrees etc.. Be interesting to see what you run when all your other issues are sorted good luck
Old Oct 30, 2014 | 09:19 AM
TheOtherDodge's Avatar
2005 E55 AMG
Congrats on the nice MPH!
