Jerky Tranny
Old Nov 10, 2014 | 01:12 PM
Vanquish59's Avatar
2019 S63 AMG (Current), 2015 E63S, 2008 E63, 2005 E55
Exclamation Jerky Tranny
Recently I did a muffler delete on my car. Sounds like a monster. Now because of this, I have jerky movements when I gas it on manual. Can this ever be a cause of a muffler delete...? When I put it on 1st or 2nd gear and I gas it, it moves forwards and backwards a few times then pulls. This all happened after the muffler delete.
Old Nov 10, 2014 | 01:27 PM
kponti's Avatar
E63
Loss of back pressure crowd in 3......2......1...............
Old Nov 10, 2014 | 01:32 PM
Vanquish59's Avatar
Please elaborate on this bro. Sounds almost what I was thinking.
Old Nov 10, 2014 | 01:55 PM
kponti's Avatar
E63
There is no real loss of back pressure. If it was substantial enough to cause the car to misbehave, you would gain or lose torque.
What i believe is happening is sound adaptation via right appendage. When you push the pedal and hear the sound increase, sound that you are not used to hearing unless the pedal is pushed even more. You instinctively back off the pedal and car falls on its face, then you rinse and repeat.
Old Nov 10, 2014 | 02:20 PM
MAN55LE's Avatar
04 E55 AMG
The supercharger has a clutch on it and engages ........and sometimes that's a little jerky....
Old Nov 10, 2014 | 02:36 PM
Vanquish59's Avatar
I will test out your hypothesis today. Sounds reasonable but not 100% sure on this one.
Old Nov 10, 2014 | 03:52 PM
Mikeki7's Avatar
CLS63, S55
guilty of that when I first modified my exhaust. Though it could also be the transmission mount
Old Nov 10, 2014 | 03:57 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
We need to get badges here on MBWORLD. I think the 'shade tree' mechanic would do great!
Old Nov 10, 2014 | 04:01 PM
Toadster's Avatar
2005 E55 AMG
Try the gas pedal reset..
Old Nov 10, 2014 | 04:31 PM
Vanquish59's Avatar
Link or doc on how to do this?
Old Nov 10, 2014 | 04:46 PM
biggking's Avatar
https://mbworld.org/forums/w211-amg/...set-works.html
Old Nov 11, 2014 | 11:08 AM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
My car (100% stock) does that whenever it's cold outside. In fact, just today I experienced it for the first time this winter. It seems like whenever the temp is below about 50 degrees that the car is a little "jerky" until things get warmed up.
Old Nov 11, 2014 | 11:09 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
common issue with the 722.6xx in cold conditions.
