Brake Fluid ???? Which kind, sorry to make a thread. Also AMG grille badge??
Old Dec 4, 2014 | 10:03 AM
SheriffDep's Avatar
13' E350 4matic, 08' E63
Sorry guys seeing different threads not totally giving answer for this and I need it know to order correct Brake Fluid for 08' E63. Its a DD no tracking. I am flushing the system next week and ordered the Motive bleeder and need to get the best fluid for it. I you can give suggestions I will pick it up today. Thanks
I noticed a member also having a AMG badge in-between the slits in his front grille. I thought it looked fairly nice and wondered where it came from. I am painting mine black next week and thought something to break it up a little might be nice. If anyone knows where it came from could you let me know please.
Again sorry to make a thread to beat a dead horse, but hopefully some quick answers and then the thread can be buried.
Old Dec 4, 2014 | 10:24 AM
E55Freak's Avatar
2005 E55 silver
EDIT: (saw you said a badge. ) I just plasti dipped this badge black to match my black grille and put it between the slits of the grille. I will snag a pic in a bit when I'm out driving and post it so you can see mine..
Badge link Badge link
Old Dec 4, 2014 | 10:42 AM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
You will find all the information you need here including a list of all approved fluids:
https://mbworld.org/forums/w211-amg/...1-e55-amg.html
Old Dec 4, 2014 | 12:55 PM
justinwrock's Avatar
Ducati
Castrol SRF!
Old Dec 4, 2014 | 01:16 PM
SheriffDep's Avatar
I saw this, but.... my question is I have a 63 not a 55. Does that even matter. I am assuming not, but want to make sure?
Originally Posted by justinwrock
Castrol SRF!
I think this Castrol is the 113$ per liter one??? Want good but the system holds 1.5 liters total I think and $250 in fluid might not be that noticable in difference. But will check that one out for sure.
Old Dec 4, 2014 | 07:19 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
MB brake fluid is DOT4+. For a DD it works great.
Old Dec 4, 2014 | 09:24 PM
bierry's Avatar
E55
Believe Pentosin Super Dot 4 is the factory fill. I use Motul 5.1 which costs a little more but has higher dry and wet boiling points. I find FCP Euro has the best prices.
Old Dec 5, 2014 | 02:23 PM
SheriffDep's Avatar
Ordered 2 L of Castrol SRF, after looking at all the different kinds, I just said why not. It is one of the highest rated. Also looked at the Motul RBF ones and the 5.1. Has anyone done the SS braided brake lines on their 55/63's. Just wondering if that helps on these.
Old Dec 5, 2014 | 06:25 PM
RobE55's Avatar
2006 E55 AMG, 65 Nova
Hi,
On the grill badge - yea, I copied another member on the idea and just made my own. EBay a purchase on the emblems and use flat stock to stick them to. Make it black before you adhere them and zip tie or tap n drill for more permanent solution. It is custom so what you put in in time and materials is what you get out of it.
Unless someone here knows a source for it. I have seen a smaller version on the new MB's but that will cost juuuuuust a little more..
Rob
Old Dec 5, 2014 | 08:27 PM
MaLicE's Avatar
W211 E55 AMG
This the badge you mean?
http://www.ebay.co.uk/itm/AMG-CHROME...item19e3e1d541
Old Dec 5, 2014 | 09:14 PM
SheriffDep's Avatar
Originally Posted by MaLicE
yes that is it!!!! The other thread was to a Amazon one, but emailed the store owner and they can't tell me how they ship. Language barrier I guess, Answered one out of three questions. And didn't answer my first to begin with.
MaLice----- are you in the UK? If so would you mind grabbing me one, and obviously I will pay for it all. Paypal?
Old Dec 6, 2014 | 07:03 AM
MaLicE's Avatar
W211 E55 AMG
Yes I'm in the uk and that would be fine drop me a pm and we will sort it
Old Dec 6, 2014 | 09:27 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
+1... for DD, OE fluid is sufficient...
Old Dec 6, 2014 | 11:29 AM
SheriffDep's Avatar
PM'd sir,
I went with Castrol SRF to try that out. Got 2L of fluid (132$) so I can make sure its flushed well. Motive pump so should be easy, and I am doing the caliper painting at the same time. So Taking those OFF the car to do it.
Stainless Steel Brake lines ????? Anyone done those?
Old Dec 6, 2014 | 11:41 AM
320 dreamer's Avatar
2003 porsche 996 turbo
easy swap for the brake lines. if your flushing the system now is the time. for fluid motul rbf 660 is as high tech as you need to go. unless your racing a road course its unlikely you will ever see temps in excess of 660*
Old Dec 6, 2014 | 02:06 PM
SheriffDep's Avatar
Doing the brakes Tuesday or Wednesday, ARE Stop Tech SS Lines the ones to get? That is about all I see except for Centric. I gotta overnight them if I get them to make it happen so yes figured this was the time.
I looked at the Motul RBF 660 but went with the Castrol SRF this time. We will see.
thanks for the advice
Old Dec 6, 2014 | 02:50 PM
stop techs are fine did you order the euro cap for the motive bleeder
Old Dec 6, 2014 | 04:40 PM
SheriffDep's Avatar
Yes got the Motive Euro cap version, and the two drain bottles. Thought for 22$ it made it easier to just have the proper container and hoses, plus the front have two nipples one for each side, so thought might as well be just as easy to do one then the other, then make sure each side is done without switching up if I had one bottle.
PR, DR, DF, PF is the pattern right? I know furthest away first. The ABS module is right in from of passenger front tire, but couldn't find (didn't look that hard) for the resivoir. Got the DIY Sticky saved, just gonna read it over before doing. OR as doing.
I will see if I can order the brake lines overnight if I can find the right one. Amazon I thought they might be right, but didn't want to guess.
Old Dec 6, 2014 | 06:37 PM
i work away from the reservoir so it pr, dr pf then df. outside front bleeder then the inside . i went to the dollar store for a container and some clear line from lowes. about 4$
Old Dec 6, 2014 | 07:43 PM
NorthernVA's Avatar
2006 E55 - Eurocharged Stage 1
I got this one off of ebay.
I cut some vinyl to separate the lettering
Brake Fluid ???? Which kind, sorry to make a thread. Also AMG grille badge??-img_0288_zps2c2c4ba2.jpg
Old Dec 6, 2014 | 07:48 PM
ilko's Avatar
E63 Kombi
ATE SuperBlue user here.
Old Dec 7, 2014 | 05:33 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Hey my friend, even IF you road race 660 is MORE than sufficient.
With a fly by wire system like the E55, you will never feel a differences with ANY fluid
Old Dec 7, 2014 | 08:28 PM
its not s much pedal feel but rather the chance of boiling the fluid on a track day. lower dry temps will boil out rather quickly and not give you the stopping distance you may need i find the rbf 660 to be fairly priced and a great boiling point. src is great fluid but very costly. ate super blue is being discontinued at most places and not allowed at a lot of hdpe events
Old Dec 7, 2014 | 09:13 PM
SheriffDep's Avatar
E63 isn't the Fly by Wire system anyway, so for me there will be feel. Understand about the feel part in the 55's. But boiling points would matter , but for track days
