!!! ATTENTION !!!! - FUEL LEAK ISSUE HAS BEEN SETTLED BY DAIMLER-BENZ... 2014.12.23
MBUSA has admitted they know of the problems but as of today we haven’t heard from them (MBUSA) nor from the dealership what they are planning to do.
Has anyone had 2 Failures on any of these these components after a Warranty Repair? Thank you!
But back to the topic, my pumps failed because they screwed up the warranty replacement of the tank and pumps in 2015. My car is at MB for exactly 3 weeks now because my pumps did fail a few weeks ago. But this can be read by scrolling up.
Mackhack;Per MB Website: https://www.mbusa.com/en/owners/part...ntenance-parts
"Fully Covered for 4 Years, Our Parts Limited Warranty protects your purchase, so you can continue to drive with confidence."
Gus//
Gus//
Late to seeing this post but JUST got this issue fixed at White Plains, NY Mercedes. Had been smelling the fuel for a while, and my Independent Mechanic (Mike in NYC, he's amazing!!!) let me know about the recall.
I got it done in 2 days, car is running fine!!! I think it literally ended for 05 cars in August
Started smelling fuel about a month ago on fill ups. Saw this thread and dropped off my car at Penski Mercedes in West Covina CA. They knew exactly what it was and said it should be covered under the new extended 15 year warranty. They even gave me a loaner vehicle for free! Car was fixed the next day and they stated the entire gas tank had to be replaced. Awesome customer service over there!
Thanks guys for all the info!!!
I just get back from MB Park Place in Arlington TX. They denied my 2009 E350 twice as of today.
What they did is punch in my VIN with service codes and MB USA will tell if that service is under warranty, which not in my case of smelling gas when fill up
Did call MB USA and got the same answer: your VIN is not under non PZEV nor PZEV with no explanation- just straight out of their database.
But now I guess why: my VIN is PZEV, but in the warranty booklet 2009 the PZEV states listed did not mention Maryland which where my used car was original sold. In this booklet also mentioned NJ origin only effective as of Jan 2009 deliveries. Which mean 2009 model delivered before Jan 2009 will not be covered by BOTH extended or PZEV 150K mi warranty. I'm sure there's lot of cases fall in to this period
Bottom line if your car is non-PZEV 2003-2009 E-class then this extended warranty applied
If your car is PZEV (VIN decode has code 917) then it has original warranty applied 15yrs/150K mi - check your warranty booklet.
My car originally sold in Maryland (now with me in Texas), at that time Maryland was not mentioned in the warranty booklet - so PZEV warranty is not applied!, so as NJ pre-Jan 2009 (as mentioned above)
At at this point, I was more than a little nervous about just trying to turn it over, so with my tail between my legs I brought her into Mercedes. Regardless Of my providing pictures with newspaper dates of the engine being in timing with not one but two Camshaft alignment tools mounted, they informed me that they would have to open her up nonetheless much to my chagrin!
I had brought with me a similar document as above referencing MB USA having had to comply with a settled lawsuit by honoring a guaranteed replacement of the Gas Tank ( including the fuel Pump and Sender and Filter!). The guys were not familiar with the issue per se, but sure enough, they called me to inform me that they did in fact inspect the Gas Tank and found it was leaking! I certainly didn't notice any smell but then again I had put maybe 50 miles on the car in the year or so that I bought it, and no more than 10 before I started the rebuild! They mentioned that it would take about a week to get it delivered from Germany and although I did pay a pretty penny to have them get her running, I have to admit it was a huge plus to have a brand new tank and all the fixings!
A giant pearl of wisdom I gleaned from the Tech was that after the engine had been dry for so long, the tech said that the only thing he did differently was to disconnect the injectors and first get the oil flowing by unscrewing the Oil Cap and toggling the key on/off ( like 50 times!) until his partner could see oil sloshing under the valve cover. Only then did they re-attach the injectors and she started right up!!
I recently did the fuel recall, and now I have a new issue with the auxiliary fuel relay/fuse burning/melting! This has happened twice to me now. Have any of you had/have this issue and if so, what was the fix to cure this issue?
Happy Holidays Gents!
Surfer70
MBUSA is one pathetic club of greed driven *******ers. I have zero left for them.
It’s time for a class action law suit agains them and we’re working on it since.
Long story short you need to document everything to the T, get them to install all necessary parts that are listed under the fuel pump itself in EPC and not just the parts that MBUSA tells them to install per the released DTB. If you’d go to the parts desk they would sell you all necessary parts. Of course it’s money in. With the warranty repair they spend as little on parts as possible for the bottom line numbers. But that repair is flawed and caused at least one E55 to go up in flames in the owner’s driveway.
We gave the service adviser a folder of about 30 documents and pictures (including the burned E55) to show them what they did wrong. At first they were butt hurt that that customer knows more about the car then they do. We spend nearly 2 hours in their office explaining and discussing the problem. After 9 weeks the apologized for their behavior and said if we want we can work with them and MB to find a long term solutions. It also helps that we know the right people and engineers in Stuttgart who had their hands in this pile of ****.
If you start a class action please let me know and I'll join you! They need to take this SH$$ seriously when lives/structures are at RISK!
I know good attorneys here in SOCAL! I have receipts of everything done at my mechanics in regards to this......
