Keyless Go Door Handle Still not working after replacement
Replacing the handle took 5 minutes. Then I tested it to find the keyless go on the new handle does not work either. I repeated the installation again making sure the connection was good.. Still nothing.
What are the chances the new handle is defective? Anyone had this issue before?
On the old handle did BOTH buttons stop working ? and same on the new one ?
others state that STAR diagnostic will list exactly whats going on....
WELL GUYS, STAR diagnostic states that there is an intermittent issue with my passenger side, with no error for my non working driver side doors. my driver front door would work here and there, then failed...so i started always opening the rear drivers door...now that has failed. both passenger side doors have never had issues while STAR states they do.
I don't understand why my maxima that I've owned for 6 yrs since new has never had this issue, yet on a car that costs nearly 3x as much, this is a frequent issue.
It amazes me that MB can engineer one of the fastest sedans ever yet can't get a door handle to work right
you can test it with a known working handle from another door as suggested in another thread, just need to connect the cable & press button while handle is hanging to see if it works
https://mbworld.org/forums/w211-amg/...ent-diy-3.html
read through this thread & like i said, replacement worked for some, didn't for others & there is no solution for those where replacement didn't work. except for 1 member but not exactly sure what he did to fix the issue from his post
@5spd97 when you say the plug in the door came out of its bracket what do you mean? When I was plugging mine in it almost appeared the the plug was on a swivel as I could move it forward and back. I had to grab it with some narrow pliers to bring it forward but from then could plug it in. Was yours doing that or completely free almost dangling inside the door.
Anybody else have this problem?
When I bought the car I noticed the front passenger wasn't working. Typically one of the two functions of the keyless handle stops working...either the OPEN or the CLOSE. For both to go out at the same time is sort of suspicious...
Then shortly thereafter I noticed the window lock was left on by the previous owner, which by itself wasn't really a big deal. Then when i tried to put down the passenger window I noticed it had a ton of trouble going up/down, and it was dragging on something... I tried to re-sync it, and still no dice.
Long story short, the FEMALE END of the keyless go handle is mounted on a swivel. So somehow when the p.o. or dealer replaced the handle, they must have dislodged this swivel an so the female end unplugged itself from the male end that is attached to the keyless handle, and it was floating around in the way of the window track.
It was quite frustrating and nearly impossible to do from the "outside". I tried it that way for over an hour to clip it back into the swivel... I knew should have made a DIY as I knew somebody would need it.
But, if you want to retain some sanity, you'll have to remove the door card (three big torx screws, bunch of snap clips) and then CAREFULLY peel away the plastic lining to reveal the inner workings of the door panel. Then while laying on my back with my face just about directly under the door, I was able to snap the female plug swivel mount back in.
So with one 'fix', I was able to get my keyless to working like new again, and the window is gliding up and down like it should with no groans or hesitations. I'm just glad nothing got messed up in the process.
Difficulty level is about a 3/10. And if I'd have disassembled the door from the beginning, it would have taken 45min start to finish. But all of the troubleshooting and struggling to do it from the outside took me about 4 hours, 3 beers and a burger, and a ton of swearing.
Installed a rear E63 09 door handle into my 07 E550 front door. Had to chop the extra bit off, and rest all lines up and installs perfectly. Before the replacement, button to lock works, but doesn't unlock. Now both the handle and the button locks the door
However, sometimes the handle unlocks and sometimes it locks. It feels like the computer is getting confused
Rest of the door seems to lock and unlock no problem and not confused
