For all of you new guys that want to go fast!
#51
Dirt Scooters
Just a well put together package. The heads I used were N/A heads so that might of helped a little. Instead on looking for crazy CFM numbers we capitalized on the lift that the cams had (.473) and made the heads flow very well for the low lift cams we have. I learned that for whatever reason my car loved to run really rich on the Q16 and that picked up a decent amount by itself. The other thing we focused on was keeping the IAT's as cold as possible for each pass. I would drop .3 on my 3rd pass just because the 20lbs of ice would be melted and the water would be like warm by then.
#52
You see how crazy that sounds.... If you want to go sorta fast add Kleemann mid headers, a 168-175 crankshaft pulley, split the cooling and add a tank up front for extra cooling capacity, a set of k&n filters and a really good road tune or atleast a dyno tune. That setup should be good for 11.3-11.6 @121-123 depending on driver, track prep, and DA
#53
The numbers that we achieved may not be the numbers you achieve with same mods. All cars on the list trap between 127-133. All different setups, lightweight wheels & breaks, no interior with racing seat, no rear exhaust, just drag radials only, lightweight battery, 180lb driver to 250lb+ driver
#54
The only way to find out if your car will run 10's is to run it. When my buddy got out of my car when I took him for a ride after i modded it he said man that really surprised me, I'm impressed. I then said yeah it's a 10sec car and he said have you run 10 seconds yet? I said no not yet he replied, well then it's not a 10 sec car until you run it. My setup is really similar to Hulk's and he ran 11.1
#55
Why could the NA heads have helped? Maybe a smaller quench in the combustion chamber for higher compression and or milling of the heads is my guess.
Nice work on the optimizing your airflow for the stock cam lift. The fuel thing sounds good too. C16 sounds like overkill for our motors, especially with stock internals. MS109 sounds good though.
All makes perfect sense. Icing down the supercharger and keeping your trunk tank ice cold has always been one of the main keys for our cars to run the lowest numbers at the track.
Maybe some weight reduction wouldn't hurt either. Thanks for sharing!
#56
#58
Ok well leave your car stock, add drag radials and you could run 11.7 with no modifications except drag radials.
#59
I know right? He's old school big block chevy guy but he was right and the pressure was on me.
#61
Dirt Scooters
#62
The N/A heads were only decked for flatness so we didn't really change the CC's of the chamber. The chambers are the same in both heads. The N/A head doesn't have the hump in the intake and my porter tested both and said hands down the N/A head was better for what I was trying to do. The exhaust port is also a tiny bit different where the EGR ports are. I went with Q16 for safety and it has 10% oxygen compared to MS109's 9%. As long as you can keep IAT's down q16 is great. There was a lot of other little things I did to the car but I can't let all my secrets out ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
#63
2014 cls63 a amg. 2018 AMG GTR
I copied Hammerdown's mods more or less. Only thing I see missing is Killer Chiller and or Methonal. For daily driving you cant beat them on these cars or any FI car for that matter. Nothing worse than losing 50+ WHP from a heat soaked car. also I'll add it seems looped rails are not needed nor do they even help on these cars. Doesn't RBJ still run stock rails even with all the power he is putting down ? I opted not to installed them after many very reputable and very fast members told me not to bother. Two years and 20K miles later beating the crap out of her seems to prove they were right.
#64
Hey you are a good sport!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Whats up with your GT500??? I demand to see pics of that beast!!
#65
2005 MB E55 AMG
Number's don't mean squat as there are plenty of factors that go into achieving numbers. Personally I couldn't tell you what my numbers are because I never dyno'd the car. All of the cars can be driven daily and they pretty much produce the same amount of power (E55rocket) may be pushing a few more ponies but the mods listed (if you want numbers) will produce between 500-575rwhp & 600-700ftlbs again that won't mean much as Bassn07 dyno'd at 447rwhp and ran 10.7@131 which is another reason why there aren't any numbers with each mod list. The point of the list is to help the new guys out by giving them the formula to go fast.
I know numbers don't mean anything. My stock 55k has ran c63 507 and a s65. Both make more power. Both should beat me and do so on paper. Both saw tail lights the entire time. But number help judge what mods to do for what power and where to start. I like to know what other people have gotten out of something before I pay for it. If that makes sense
#66
#67
I got to 11.1 with modded stock manifolds
I think with a better 60' it would have been 10s however with completely stock manifolds I don't think it's possible.
#69
2005 MB E55 AMG
My goal is 600-650hp on motor. But then again power aside I would be happy with low to mid 11's on the motor. I will add some spray to dip into the 10's but that wont be for a while.
#71
You can add Kleemann mid headers, a 168-175 crankshaft pulley, split the cooling and add a tank up front for extra cooling capacity, a set of k&n filters and a really good road tune or atleast a dyno tune. That setup should be good for 11.3-11.6 @121-123 depending on driver, track prep, and DA if you want to go faster you will have to upgrade to a 82mm TB, upgrade your injectors and increase your crankshaft pulley size and retune
#72
This is my list of mods:
EC 84mmS/C pulley
Belt-wrap kit & ASP pulleys
EC 550cc injectors (stock fuel rail)
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
AFE Pro Dry S filters
Wrapped, custom mid-length headers , no cats, x-pipe, no resonator (stock mufflers for now - looking at electric cut-outs & other mufflers)
EC Ported/polished heads (stock cams)
Weistec 170mm Modular CP
EC trunk tank (Dad's)
EC built transmission, 3K converter & TCU tune
Quaife LSD
EC dyno tune
548whp/610wtq (93 octane) on Jerry's new DynoJet 424XLC2 with the linx system (front & rear rollers linked together)
She is my daily driver. I haven't tracked her, yet, so, I don't have times to compare with the others here. But, she's strong.
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
#73
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
#74
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#75
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
EC 84mmS/C pulley
EC 82mm TB
EC Heat Exchanger
NGK LFR7AIX plugs
Quaife LSD
EC dyno tune
